Regs - Shunt vs Series - Page 3 - diyAudio
Old 14th December 2012, 01:33 PM   #21
qusp is offline qusp  Australia
qusp's Avatar
Why I'm bothering with the preregulator ?
well that too, but the main thing, why are you bothering spending sooo much time on this question of the regulator output caps? they are not only not locally decoupling anything, they are driving another regulator.... any good regulator will render the difference in these caps utterly insignificant to 'sound quality' if it didnt it would be a pretty crap regulator
popular opinion would have you replacing all those evil ceramics on the pins of devices with film caps, even though for local HF decoupling they are orders of magnitude worse than ceramics
it sounds to me like you are taking opinions/recommendations out of context, or whoever is parroting them.
Old 14th December 2012, 02:00 PM   #22
Telstar is offline Telstar  Italy
ceramics (of good quality) are suitable for psu decoupling.
"The total harmonic distortion is not a measure of the degree of distastefulness to the listener and it is recommended that its use should be discontinued." D. Masa, 1938
Old 14th December 2012, 02:08 PM   #23
dahlberg's Avatar
So it's your firm belife that components in a preregulator can not make any difference soundqualitywise as long as the last regulator is "good" ?
Old 14th December 2012, 02:30 PM   #24
Out of context !
Again !
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 14th December 2012, 02:50 PM   #25
qusp's Avatar
I really suggest that you do some research as to what the roll of capacitors are in this circuit, how that relates to this application of this circuit and audio power supplies in general...
context is everything... not just in my words here, but very specifically for capacitors and each ones roll in the circuits and the specific positions they are placed in.
Old 14th December 2012, 03:05 PM   #26
jackinnj's Avatar
The Salas shunt regulator tested very well indeed, but fared poorly in the listening test.
Walt Jung's interview in AX has been archived to his website and has a very good explanation of the reasons why a shunt regulator should perform better. When I can get my panel of listeners together, we'll take a serious listen to the 2012 edition of the Jung Regulator.
Old 14th December 2012, 03:51 PM   #27
cotdt is offline cotdt  United States
Send a message via AIM to cotdt
I wonder what is the advantage of shunt regs. I know shunt regs can source current, but don't see how this is an advantage.
So far I've tried the Salas shunt reg and Twisted Pear shunt reg, and both of them were an improvement over the series regs that they replaced in my DAC and headphone amps. They have a clear advantage over the LM317 chip sonically.
Old 15th December 2012, 09:30 AM   #28
Shunt Regulators have an absolute limit on maximum current.
If the tiny amount of capacitance between the reg and the circuit (typical of most regulators of all types) cannot supply the demanded current then the performance will fail.
This must impinge on sonics.
I think many underestimate the transient current demands of most audio circuits.
Some even think that all ClassA amplifiers/stages draw constant current.
It's fallacies like this that lead unthinking builders down the route of sonic disasters.
regards Andrew T.
Old 15th December 2012, 11:45 AM   #29
regal is offline regal  United States
But this is why you over design the shunt (make it waste much more current than its load will ever pull), the load's ground becomes the limiting factor.
I mean it/s not like transients are faster than the current can pull thru the wire right ?
Old 15th December 2012, 12:15 PM   #30
If the wire has inductance (all do have) then the current demand can be faster than the wire can supply.
regards Andrew T.
Simplistic Mosfet HV Shunt Regs Salas Power Supplies 5746 15th June 2017 08:05 PM
Simple Super Shunt and Simple Super Shunt w/CCS vs. JSR03/05 (and other series regs) hollowman Power Supplies 45 5th July 2013 10:50 PM
Glow tubes as series regs ? mach1 Tubes / Valves 4 28th April 2009 09:19 AM
Multiple regulator question... regs in series... Nordic Power Supplies 3 22nd September 2007 02:35 PM
Copyright 1999-2017 diyAudio
