Old 30th March 2013, 09:12 PM   #1
Phisci is offline Phisci  South Africa
Default Easy way to listen to power amp via headphones
Hi guys, I would like to apply a few simple mods to my power amp (class a and also class d). If I connect say 20k resistor to the output of the power amp, would that allow me to safely listen to a 32R headphone?
Old 30th March 2013, 10:22 PM   #2
JMFahey is online now JMFahey  Argentina
JMFahey's Avatar
You don't state the amp Power !!!!!
Old 31st March 2013, 04:44 AM   #3
djoffe is offline djoffe  United States
There are two ways:
1. Simplest---2490 Ohm resistor in series with tip and
a second 2490 Ohm resistor in series with ring.
common ground to sleeve.
2. Better --- many folks cite the benefits of driving the headphones with a low impedance. Assuming a 50 Watt Amp (8 Ohms), then a voltage divider of 330 ohms feeding 4.7 Ohms is a pretty good compromise. It gives about a 4.7 Ohm output impedance, resulting in a damping factor of 6x with 32 Ohm phones.
If we assume 98 dB SPL at 1 mW with 32 Ohm phones, the 50 Watt amp would put an SPL into the phones of 100 dB SPL (jackhammer at 1 meter).
If your phones aren't quite so sensitive, you might have to drop the 330 Ohm resistor a bit...you just have to watch it, as even the 330 Ohm resistor dissipates 1.2 Watts with 50 Watts (20 Volts RMS) out of the amp.
Old 31st March 2013, 05:39 AM   #4
Thanks guys, the amps are 500w class D and 120w class A.
What would the recommended wattages be on the 330R and 4.7R be?
Old 31st March 2013, 07:45 AM   #5
JMFahey's Avatar
120W Class A?
Which amp is it?
Old 31st March 2013, 08:01 AM   #6
Krell ksa80
Old 31st March 2013, 01:08 PM   #7
330 Ohms, 2 Watts ok, unless you do a lot of full power testing on the amp for extended periods...in which case I'd use 5 Watts...
4.7 Ohms, a 1/4 watt resistor would be ok.
Old 31st March 2013, 01:52 PM   #8
hello,
may I suggest ESP's solution?
Headphone Adaptor for Power Amplifiers
Old 31st March 2013, 02:53 PM   #9
JMFahey's Avatar
330 Ohms, 2 Watts is fine for the 80W Class A amplifier.
Now, in a 500W amp, Class A or otherwise, you'll need a 15W one.
Why would anybody use headphones to listen to a 500W Class D amp is beyond me , though.
Or burn 400W dissipation, also to listen through headphones, same thing.
*Maybe*there's some reason none of them have headphone out .
Old 31st March 2013, 09:55 PM   #10
jxdking is offline jxdking  China
Another thing should be considered. The impedance of the headphone is not constant. It will change as frequency changes. If you just put a 330 in series to headphone, the frequency response might not be flat any more.
Head phone will be more like current driven if you put enough resistor to it. You will get different sound.
Budget CD-player to listen with headphones ßart West-VL. Digital Source 18 23rd February 2013 05:15 PM
Listen to a car stereo with headphones? nooby2scooby Car Audio 2 4th March 2012 11:05 PM
Listen to 6DJ8 Triode through Power Chip IC. Easy project. lineup Tubes / Valves 3 28th April 2011 02:41 PM
dedicated power amp for headphones PreSapian Headphone Systems 5 10th August 2010 03:09 AM
Low power tube amp for headphones trespasser_guy Tubes / Valves 112 28th January 2003 10:34 PM
Copyright ©1999-2013 diyAudio
