Amplifier with nested Miller compensation
Old 17th April 2013, 10:59 AM   #11
matze is offline matze  Germany
Default One more example
Here is a further example of Bob's demonstration amplifier (page 63 of his book), now with
two nested Miller compensation loops.
The unity gain crossovers again are around 400 kHz. This is achieved without compensation capacitors in
global feedback loop or over the LTP degeneration resistors. Thus, as Bob points out in his
book and is also my experience, the danger of grainy sound due to high-frequency overloading is reduced.
Simulated THD at 10kHz is 1.7ppm at 1V rms into 4ohm, 3.7 ppm at 10V into 4ohm (readings
from the .four command). See also fft-10k-1V.png and fft-10k-10V.png.
The Bode diagrams of all loops in global-loop.png, nested-loop-1.png, and nested-loop-2.png look like in a text book.
A rough estimation of the VAS loop behaviour is depicted in loop-vas.png. It is not that ideal,
but the phase margin still appears to be larger than 60 degree.
OPS quiescent current is about 50 mA, i.e. total supply current is lower than 100mA.
There is a problem with all loops (as in Bob's original amplifier, too), if the load capacity C8 is set
to e.g. 10nF, and the load resistor R20 to 1K. Then the series resonance between L2 and C8 remarkably
reduces the phase margins, see series-resonance.png.
Unfortunately, the effect does not vanish with higher OPS quiescent current. Probably, only faster
output transistors can cure that.
Behaviour during turning on and off and clipping is considered in the next post.
Matze
Old 17th April 2013, 11:07 AM   #12
Default Clipping and turning on/off
Clipping behaviour is not nice, see clipping.png. At least, the amplifier remains stable. Do not yet know what happens if one includes short circuit prevention in the OPS.
Probably it would be best to add some circuitry to prevent clipping at all.
I also had a look on behaviour during turn on and off. In the simulations, main supply voltages are turned on after one second, and turned off after 5 seconds.
In no-clamp.png, one sees output excursions to both supply voltages on turn on, but no high-frequency oscillations relating to only conditional stability.
In clamp-pos.png, Q28 together with D8 and D9 restricts the positive voltage at the Vbe multiplyer,
so that only around 300mV can appear at the output. For that, one would need additional circuitry in place
of the PWL voltage source V3 which turns Q28 off after 1.5 seconds.
The high negative voltage can be supressed by delayed biasing of Q16 due to R41/C17, see clamp-both.png.
I think that nested Miller compensation may be a valuable ingredient to build good amplifiers.
Audio amplifier construction should not neglect techniques routinely applied in operational amplifiers.
Are there any comments?
Matze
Old 17th April 2013, 02:02 PM   #13
jxdking is offline jxdking  China
Nice try!
The outer Miller loop gets feedback directly from output stage so that it can achieve very low THD.
That's the same idea as TMC.
BTW, did you sort out the Math
Old 17th April 2013, 04:27 PM   #14
Originally Posted by jxdking View Post
Nice try!
thank you for the comments.
I aggree that the approach lies somewhere between "our" TMC approach and the conventional nested Miller compensation. As in the former, all but the most inner loop (around VAS) include the output stage, thus increasing the NFB around VAS and OPS. From the latter stems the idea of recursive application of the compensation scheme, the difference being that in OPAs all "right end sides" of the Miller capacitors are connected to the same point, usually the output.
Doing the Math certainly would be a good undertaking. May be it could bring more justification and better dimensioning rules than the simple explanation that I tried to give in "matzes-amp.pdf" in post #1. To my defense I can only say that this rather informal approach is along the lines of Johan Huijsings OPA book, which provides a very clear but accessible explanation of all this stuff -- except of course the tricks with the additional zero.
A mathematical treatment could bring a better understanding especially of the transient behaviour. To be honest, I'm also a bit suspicious whether these nice 90 degree phase margins and 20dB per decade roll-offs really mean that the whole circuit will (at least in principle) behave like a simple topology with first-order characteristics.
From my breadboard amplifier (post #1), where I strechted the whole idea as far as possible, I only can say that the square wave response looks as nice on the oscilloscope as in the simulation.
BR,
Matze
Old 20th April 2013, 09:33 PM   #15
Probably, it will be necessary. I'm not sure about possible higher-order characteristics and others refer to Bode's results that seem to forbid first-order behaviour with increased amount of feedback.
On the other hand, simulating the amplifier and looking at both frequnecy responses and transient square-wave responses (also at internal nodes), one does not see any overshoots in the wrong direction or any ringing. For my simple understanding, this altogether would point to first-order behaviour.
So I will have to look into the text books. This is the system under study from post #7:
http://www.diyaudio.com/forums/attac...ation-fig3.gif
My plan is to first recap the transfer function for a closed loop of a miller integrator and a preceeding transconductance stage (standard OPA theory). Then I have to include an additional pole/zero (the nested Miller cap with zero-providing resistor) in the originally resistive feedback path, giving a modified closed-loop transfer function. Finally, this block should be included into the next outer loop with additional transconductance stage and resistive feedback network. If one can show that the closed-loop transfer function of this outer block has first-order characteristics (of course given the poles / zeros are placed properly), then the work is done.
This certainly sounds too simple. What do you think? Is this the right way?
Best regards,
Matze
Old 21st April 2013, 09:57 AM   #16
Default Mathematics for first-order behaviour
In the text below, one sees that each additional feedback loop with nested Miller compensation and additional zero leads to a new first-order transfer function that is theoretically the same as the old function without the additional loop. This, of course, only holds true, if component and transconductance values are exactly matched. Otherwise, pole-zero pairs are created.
From my simulation examples, e.g. post #11, with not at all perfectly matched values, one can follow that this is not a too great problem. All loops still exhibit a nice gain slope of 20 dB per decade.
Matze
nmc-first-order.pdf
Old 21st April 2013, 02:29 PM   #17
Matze
Attachment 343885
Hi, Matze,
It will be different cases which depends on whether the outer loop includes output stage or not.
1. If not, the outer loop must maintain the same loop gain bandwidth as you desired, not the inner loop. It is not good idea you put a Zero in the outer loop. It will worse the Gain Margin. I guess with out that Zero, it will remain stable. You will get a super VAS with very HIGH DC gain, and very low output impedance.
2. If outer loop includes output stage, the inner loop should maintain loop gain bandwidth. What I would do is put a EF right in front of VAS. In order to maintain the same as loop gain bandwidth, I would put a 100nF capacitor to the base and emitter of that EF. (That will bypass that EF at high frequency). So far, you will find the loop gain is pretty much a 2 pole compensation. I believe you will get there. The final step is put outer miller capacitor to the base pin of the EF and the output of Output Stage.
The idea is to come up a 2 pole compensation so that you can use the extra gain to compensate with the outer Miller loop. You will get 2-pole performance and 1-pole like frequency response.
I haven't tested yet. Hope that will work.
Old 21st April 2013, 04:55 PM   #18
Hi jxdking,
thank you for reading and commenting the ideas.
First, I have to clarify that in the small math derivation, the most outer global feedback loop was skipped. As it is assumed to be purely resistive, it will not change des system characteristcs in question. For a closed-loop system, the calculated transfer function G(s) would equal the loop gain (in the closed loop) times feedback ratio. If we assume for simplicity a feedback ratio of one, unity gain crossover would be at 1/(2 pi R C). For that, the first transconductance stage just had to be thought as a stage with differential input, one serving as "real" input and the second connected to the output b(s).
I always assume that the output stage has a low-pass characteristic whichs dominating frequency is much higher than the unity gain crossover above. Let's say 400 kHz for the latter and 4 MHz for the former. Thus, we can place the OPS at any place where the unity gain crossover frequency is well controlled, leaving the additional OPS pole with little influence. In the second picture in the math text, this would be between the VAS integrator and the feedback tap to the Miller capacity with additional resistor. The most inner integration capacitor remains connected directly to the VAS output / OPS input. ( Otherwise, we would produce the so-called "inclusive Miller compensation" with its known difficulties.)
Summing up, both the - in the math skipped - global feedback path and the feedback path with capacitor plus resistor are connected to the OPS output, creating the desired NFB (see also my examples with Bob's demonstration amplifiers and the implemented and bicely operating breadbord schematic from post #1).
The stability margin penalty from including the OPS into these loops is not considered in the math, since we also do not consider it when discussing e.g. the TPC compensation scheme with its second-order characteristic. In this case, only the slopes created by the feedback network around the VAS are discussed, the additional low-pass of the OPS is assumed to be high enough in frequency as to not remarkably change the picture. (Building an amplifier with a unity gain crossover just in the vicinity of the dominating OPS low-pass frequency probably is only feasible if one has a very well defined load impedance.)
The point of a possible reduction of stability margins due to the "zero-resistor" in a feedback loop was also mine when thinking about such a scheme. See the discussion in "matzes-amp.pdf" together with figures 1..5 in post #1 (figures corrected in a later post). The trick with the additional voltage divider between OPS output and Miller capacities, except around VAS, may solve the problem in most cases. BTW, as this is only possible if e.g. the capacitors are increased by a factor of 10 or 20, the trick probably isn't applicable in integrated circuits.
I still hope that the whole scheme does, at least in principle with ideally matched poles and zeros, produce a circuit with first-order characteristics. All relevant feedback loops evaluated show a gain slope of 20dB per decade.
What do you mean by performance? Is it just the final result or do you think that we can have a relevant feedback path in the circuit with second-order characteristics, while the overall behaviour is first-order?
I'm wondering about the loop one can open when inserting a probe between OPS output and "right-hand sides" of all feedback paths (except VAS) glued together. This topic is also discussed in the thread on Dadod's TT-TMC. I'm still convinced that it has no physical relevance, as it is the sum of all feedback paths, but not the feedback path important for any single loop starting "earlier" in the amplifier.
Is there anybody who can comment on this last issue?
Thanks and best regards,
Matze
Old 21st April 2013, 06:31 PM   #19
Dave Zan is offline Dave Zan  Australia
I think one problem with your derivation is that there is an implicit assumption of perfect minimum phase. If phase behaviour is perfectly minimum then every pole but one can be perfectly cancelled and the result will be first order behaviour.
This is also the assumption behind Cherry's Nested Dif. Feedback Loops.
If you can do this then do you need nested loops? Just cancel the poles and have a first order loop.
This kind of hidden assumption can be quite tricky.
More on the outer loop issue when it is not bedtime here!
You could try a PM to JCX. Just his area, when he feels inclined to comment.
Best wishes
David
Old 21st April 2013, 07:21 PM   #20
jcx is offline jcx  United States
probably requires harder thinking than I can manage during allergy season
Amplifier with nested Miller compensationHide this!Advertise here!
VAS with Miller compensation zero GEirin Solid State 9 28th February 2010 01:36 PM
Miller compensation with a series RC network? Bricolo Parts 5 27th February 2010 02:19 PM
Cascode VAS miller compensation Rafael L Solid State 9 5th March 2009 02:06 AM
Miller compensation - pros/cons? Joel Tubes / Valves 25 14th January 2006 10:20 PM
No miller compensation Electron Solid State 38 10th January 2005 12:40 PM
