smart way to charging batteries. - Page 3 - diyAudio
Old 27th November 2003, 07:08 PM   #21
georgehifi's Avatar
Send a message via MSN to georgehifi
Yeah, Peter before i settled for 12+ ct 12- and low dropout regs i did consider 24+ ct 24- and i did find i charger on the web expensive $150 or so you`ll have to do a search in Google and i found it by just saying (24v battery charger) and it was the only one i found . It was for Panasonic Panavision Professinal Movie camera and i think it was built by Panavision as well about the size of 2x cigarett packetts together.
Cheers George
(ps let me know if you find it again as i may go to 24v as well)
Avatar : Production Lightspeed Attenuator
www.lightspeedattenuator.com
Old 27th November 2003, 08:18 PM   #22
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
I will build one.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 28th November 2003, 02:20 AM   #23
li_gangyi's Avatar
will ya give use the schematic when you are done researching on it?? seems pretty hard to charge 2 batteries in series...the problem of unmatched batteries becomes a real pain...
Kids in the back seat cause accidents...Accidents in the back seat cause kids...
Old 28th November 2003, 02:48 AM   #24
EJ is offline EJ
Use one of the circuit I mentioned earlier for each battery. No problem at all putting them in series. Just make sure that they all connect to different AC windings, otherwise the transformer might get cooked. Just use the cheapest transformer(s) you can find since they are separated from the circuit by the relay once the AC power is pulled off, and won't affect the audio signal at all. Very easy to use and not expensive at all.
Before connecting the charger to battery, adjust VR1 so that the output voltage is 13.8V. The charging current is approximately 0.6V/R3.
The following picture is a battery-powered +/-24V amplifier with four 12V/4AH batteries in series.
Old 28th November 2003, 02:56 AM   #25
li_gangyi's Avatar
For the trafo what would I need?? One with dual 15VAC windings??
Old 28th November 2003, 04:29 AM   #26
EJ is offline EJ
You will need one separate winding for each battery-charging module.
The current capacity is not that critical. Being able to supply the charging current you want will be sufficient. In my own power amp (not the one in the picture) I used 4 15V/1A windings to charge 4 batteries at a current of 500mA each.
Old 28th November 2003, 05:43 AM   #27
li_gangyi's Avatar
okie thanks...I do understand a bit of chinese...so maybe I'll copy that schematic...btw how long does your amp run?? and where did u get the batteries?? Are they cheap?
Charging batteries with a variable power supply jacquesl Power Supplies 4 13th March 2013 07:52 PM
Charging Lithium ion batteries Diy_Ambitious Power Supplies 11 28th January 2013 06:42 PM
charging 3x 12V batteries in series. RichJones Solid State 7 24th September 2003 10:10 AM
Copyright ©1999-2017 diyAudio
