Old 26th November 2003, 10:07 PM   #1
Default 7812/7912 regulator questions
I am using these regulators in the preamp section of my amp. I'm looking for some more power and I have some larger transformers around. Currently my rails are 19v, I want to attach a transformer that will give 58v rails. I only pull a few mA from the regulators so dissipation is not an issue. If the regulators do not produce +/-12v bad things will happen in the amp. Am I safe to attach this transformer?
Old 26th November 2003, 10:09 PM   #2
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
How bad?
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 26th November 2003, 10:42 PM   #3
HDTVman is offline HDTVman  United States
Those regulators will not survive input voltage that high. You will need to drop the voltage down with a preregulator or dropping resistors. If you know how much current these +- 12 volt regulators supply to the circuit just chose a resistor value to put in series with the regulator input that will give you about 18 volts or so on the input. Be sure that the resistor is high enough wattage to safely handle the heet generated.
You could just feed the regulators with the low voltage transformer you have now and power the rest of the amp with the higher voltage transformer. That way you don't need to change anything other than building a seperate highvoltage supply for the power amp.
Without knowing more about the circuit that's about all I can suggest.
Later BZ
What ever makes the tunes flow
Old 26th November 2003, 10:43 PM   #4
I think the maximum input voltage for these regulators is around 36V.
Old 26th November 2003, 11:16 PM   #5
How bad?
Things like the entire amp latching and putting large DC currents on the output.
Old 26th November 2003, 11:29 PM   #6
Why don't you use separate transformer for the amp and separate for preamp section. Or if you are using toroid you might add extra windings to big transformer, just enough to provide voltage to 78xx/79xx regulators?
www.audiosector.com
Old 26th November 2003, 11:39 PM   #7
diyAudio Senior Member
fdegrove's Avatar
No, but you could use some LMxxx to preregulate.
The 78/79xx series aren't really all that good sounding but I can't see how on earth that amp is going to be more powerful by changing the VA rating of the xformer and sticking to the same rail voltage and current ratings????
Frank
Old 26th November 2003, 11:46 PM   #8
With a new transformer he's increasing rails from 19 to 58 V. Don't forget to check electrolytics, if they can take the voltage jump.
www.audiosector.com
Old 26th November 2003, 11:49 PM   #9
Gee, I think I hear an echo.
Old 26th November 2003, 11:53 PM   #10
fdegrove's Avatar
So:
Yes but sticking to say, +/- 12V is not going to give more output power to the amps though, is it?
Or perhaps a misunderstanding on my part...
Frank
7812 vs 7912 KU40 Solid State 4 13th June 2006 03:30 PM
7912 needing minimal load? Pierre Power Supplies 3 25th May 2006 12:28 PM
How do I know a 7812 is broken? ericpeters Parts 14 12th January 2005 11:15 AM
Lm7812/7912 kinser Chip Amps 9 22nd November 2004 09:55 AM
7812 TO220 regulator little help please strulon Tubes / Valves 19 23rd May 2003 02:54 PM
Page generated in 0.12099 seconds (73.51% PHP - 26.49% MySQL) with 10 queries
