Correct way for PSU?
Old 21st March 2013, 07:52 AM   #1
Walkalone is offline Walkalone  Viet Nam
Default Correct way for PSU?
What's the correct way to tracks on power supply PCB with full 8 diodes regulator?!
1. Common tracks for GND of 2 haft wave. Star ground is this track, not the point (the entire length of the track). It's will connect pins (+), (-) of caps and are the GND of circuits.
This is usual way. With < 8 total caps, it's good. Reference power supply sells at DIYAUDIO Store use it. But with the very many caps, the length of track is the problem. The track's resistance make bad effects.
2. Separately tracks and connect all at the star ground.
3. Use ''T-Ground''. Ex: On positive rail, separately track for cap banks by 1 track. GND for cuicuits by 1 separately track. It's common GND. All track connect at star point. Similar with negative rail.
So, (2) same way with (3).
What's the best way? I think (3). Anybody can suggest me.
Old 22nd March 2013, 07:42 AM   #2
Oh, come on. Nobody can't help me?
I think (3) is excellent ways. What do you think?
Please give me your opinion!
Old 22nd March 2013, 10:02 AM   #3
CBS240 is offline CBS240  United States
CBS240's Avatar
You description is vauge. Can you draw out what you mean? Typically after the rectifier you have a set of filter caps to which each gnd return goes to the centertap. Then you may have a small resistor to a capacitor bank that powers the amplifier. The gnd returns for these are seperate paths to the centertap forming the star gnd point. The concept is to seperate the charging pulses from the power transformer from the high current pulses returning from the speaker.
All the trouble I've ever been in started out as fun......
Old 23rd March 2013, 05:58 AM   #4
Ok, i'm attack the files.
In left, it's usual/popular and simply in layout. If you have total <8 caps, the star ground is the length of common track, its sort. The track resistance is not significant. Circuit's good.
Right, i think call it by ''T-ground''. Separate track connect caps bank and return at star point. Both pos. & neg. so. GND return from circuits, Speakers are connect at star point too.
I'm worry because if you use too many caps, the track length would be too large, the resistance is too high. (1) way is simply in layout more than (2), (3).
My plan is use total 20 caps in main supply.
If you are, you will choose?
Old 23rd March 2013, 12:50 PM   #5
DF96 is offline DF96  England
The left-hand circuit is not too bad, apart from the labelling. The ground bus in the PSU should not be labelled 'main star ground'; it isn't a star and it isn't main.
The right-hand one will have serious buzz problems.
The proper way to do it is to use a ground bus in the PSU, as in your left-hand circuit, but do not make even the clean end of the PSU the signal star ground. Instead, have a separate star ground which the PSU ground also connects to. This is spelled out in lot of places, so I cant imagine why people still keep getting it wrong.
Old 23rd March 2013, 02:48 PM   #6
I don't understand exactly what you want say to me. If you can, please use a pic to describe it.
Old 23rd March 2013, 06:21 PM   #7
jaycee is offline jaycee  United Kingdom
Imagine your right hand picture, but do not make the star point between the rectifiers. The star point should be at the capacitors.
Old 23rd March 2013, 06:24 PM   #8
No, the star point should be to the right of the capacitors. The cap themselves should be on a bus, like the left-hand circuit.
Old 23rd March 2013, 06:29 PM   #9
Yeah, that is what I meant This is the power supply board I have used for a gainclone, no hum problems. The bridge rectifier and transformer centre tap connect on the left. The star ground point is just left of the fuses, between the capacitors.
Old 23rd March 2013, 07:02 PM   #10
PMI is offline PMI  United States
@Walkalone: I think what they are telling you is to keep the common point of the rectifiers, away from the place where the speaker return (speaker ground), and other signal grounds are connected together. "star" ground is just a word, a label that people can disagree on...
So, imagine a long circuit board, with rectifiers, or rectifier connections at one end. Then, a double row of electrolytic capacitors, like the layout above. 2-4-8... As many as it takes for your project. Perhaps some small resistors to help filter the AC ripple. At the opposite end of the circuit board, a connection or connections for signal grounds, speaker returns, control circuits etc. In between, a medium trace which connects the common point of the two rectifiers, to the common point of all the other ground connections.
It might also help to post the intended use of the power supply, you could get better advice if you do.
Correct way for PSU?Hide this!Advertise here!
Correct implementation of R-C-R-C filtering in PSU Gopher Power Supplies 25 23rd December 2012 08:42 AM
Is PSU Designer II correct? zxx123 Tubes / Valves 7 20th January 2008 06:21 PM
is this PSU correct? zafira1981 Chip Amps 15 18th November 2005 11:33 PM
Correct PSU Wiring Rarkov Parts 6 10th October 2002 09:11 PM
Copyright ©1999-2017 diyAudio
