Power Amplifier WITHOUT compensation - diyAudio
Old 20th March 2013, 10:39 AM   #1
lineup is offline lineup  Sweden
lineup's Avatar
Default Power Amplifier WITHOUT compensation
Compensation there is a lot of talk about.
Most power amplifiers needs more or less compensation.
But I know there are a few amplifiers that do not need compensation.
For example I think some of HIRAGA amplifiers does not use compensation.
NELSON PASS has designed amplifiers without compensation. I think.
My Questions:
1. Which amplifiers do you know about without compensation?
2. Are there any benefits of designing amplifiers without compensation.
Drawbacks?
3. How can we design amplifier without compensation?
What is the way to do this?
If you have any examples in a schematic, it would be nice if you posted it.
lineup
Old 20th March 2013, 03:18 PM   #2
Bonsai is offline Bonsai  Taiwan
Bonsai's Avatar
Lineup,
VFA's usually require compensation ('comp').
The reasons are
1.VFA's typically consist of two gain stages - an LTP followed by a TIS. Lets consider the output stage gain for now as unity. Two gain stages mean the open loop gain is very high. On a conventional discrete design, 80dB is quite easy to achieve. The -3 dB open loop bandwidth of this type of arrangement (uncompensated) means a UGF c 10 MHz or higher.
2 . The output stage will usually have a pole at a few MHz, such that the overall slope at the UGF will be a minimum of 40 dB, but usually higher than this.
3. When you close the loop on a system like this, it is unstable, and you get oscillation.
4. The cure is to compensate the loop such that it intersects the UGF at 20 dB per decade, thus pushing the second pole (which would add another 20 dB to the slope) well above the UGF and with a gain of < 1
5. For a typical BIP output stage, you would need to set the ULGF at about 1 MHz, and for a MOSFET amp 2-3 MHz is about right.
6. You do this by adding degeneration and or Cdom to the front end:-
ULGF = 1/(2Pi * 2 Rdegen * Acl * Cdom)
CFA's on the other hand, only have one active gain stage: the TIS
This means their loop gain is much lower. A typical discrete CFA will have an open loop gain of about 60 dB. However, this usually means that the UGF slope intercept is 20 dB, and, you therefore can get away without having to apply any comp, or just a little bit. An important outcome of this is that the bandwidth of this topology is much wider, so that at higher frequencies, the loop gain difference between CFA and VFA is not that big.
How to get away without compensation?
In a CFA, the TIS input current under dynamic conditions is controlled by the value of the feedback current. Typically, the TIS (both VFA and CFA) will have a pole formed at HF due to the TIS input current and the TIS input capacitance ( before any Cdom is applied). In a CFA, you can apply overall compensation by adjusting the value of the feedback resistor, since this will define the dynamic input current into the TIS input, working with its associated capacitance to set the UGF.
In practical CFA power amplifiers, it is more convenient to simply use a comp cap - but, it is quite possible to do it with just the feedback resistor.
bonsai
Amplifier Design and Construction for MUSIC! http://hifisonix.com/
Old 20th March 2013, 03:22 PM   #3
If you think you have one without that cap, it is in fact hidden in some junction capacitance. Compensation is an inherent need from stability requirements and physical limitations.
Samuel
Old 20th March 2013, 03:36 PM   #4
Bonsai's Avatar
Agree.
I have assumed that Lineups question means 'no caps'. I don't think it's possible with a VFA - unless you set the LTP current very low, and use a lot of degen. You could load the TIS stage as well, or use resistive feedback around it, but that would be cheating since you would just be killing the loopgain. On CFA is is possible because typically you have a lot more latitude due to the lower OLG.
Let me add, this would not be my preferred way to comp a CFA.
bonsai
Old 21st March 2013, 02:18 AM   #5
jxdking is offline jxdking  China
without Cdom makes amplifier behavior unpredictable.
I find even CFP(COMPLEMENTARY FEEDBACK PAIR) sometimes has stable problem.
Old 21st March 2013, 02:13 PM   #6
On CFA is possible because typically you have a lot more latitude due to the lower OLG.
The magnitude of DC open-loop gain does not affect the required compensation capacitor value. And current-feedback follows the very same basic compensation law--gm/C. To get lower unity gain bandwidth, either reduce input stage transconductance or make the compensation capacitor larger. What is true is that most current feedback amplifiers have much lower input stage transconductance, because the feedback network effectively degenerates the input stage. That's why you may get away with just the junction capacitances.
Samuel
Old 21st March 2013, 02:31 PM   #7
Bonsai's Avatar
The feedback network indeed acts to degenerate the input stage transconductance as you point out. The additional gain stage (the LTP) provides VFA's within the (very) much higher gains, and here it is instructive to think about things from UGF as well.
bonsai
Old 21st March 2013, 04:14 PM   #8
wahab is offline wahab  Algeria
My first symmetrical differential circa 1985 had no miller caps
and was perfectly stable , design is sym. differential + sym. Vas
that did drive directly three lateral fet pairs.
Old 21st March 2013, 11:51 PM   #9
Bonsai's Avatar
That was your comp: the input capacitance of the mosfets.
Can you put up a picture of your square wav response?
bonsai
Old 22nd March 2013, 04:46 AM   #10
Here a picture from the simulator , i ll post the schematic later
on a relevant thread about symmetrical differential basic topology.
Actualy , only part of the compensation is made through
the fets input capacitances used as shunt.
Elektor s Crescendo used the same scheme but was hardly
stable , due to the cascoded VAS that cant be compensated
this way.
Anyway , perfs where not extraordinary but good enough
for the intended purpose , i.e , stage monitor amplifier for
my keyboards set.
alteration of the power supply from the power amplifier Harman Kardon HK870 at 220. alexkmp3 Power Supplies 4 11th December 2012 04:39 PM
Error amplifier compensation desighn in SMPS MarianB Power Supplies 11 30th October 2012 01:14 PM
An amplifier to take to University - A small low power integrated amplifier monty78pig Solid State 33 31st August 2012 06:00 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright ©1999-2014 diyAudio
