PeeCeeBee
PeeCeeBee
Old 28th May 2013, 12:08 PM   #501
stoN_Cold is offline stoN_Cold  Serbia
stoN_Cold's Avatar
Originally Posted by nikosokey View Post
Hi ZeoN_Rider
I had bought a total of 16 pieces for my Golmund Clone amplifier. I used twelve in amplifier and I stayed with two couples for VSSA amp.
I had ordered from the PROFUSION and pay them by bank transfer.
Regards Nikos
PROFUSION, link please!
Regards zeoN_Rider
Old 28th May 2013, 12:18 PM   #502
nikosokey is offline nikosokey  Greece
nikosokey's Avatar
Regards zeoN_Rider
Here is my brother
Lateral Mosfet
Old 28th May 2013, 12:24 PM   #503
stoN_Cold's Avatar
Here is my brother
Lateral Mosfet
Thanks bro but I can't find
Regards zeoN_Rider
Old 28th May 2013, 12:29 PM   #504
nikosokey's Avatar
Regards zeoN_Rider
Profusion Splash Screen
Old 28th May 2013, 12:49 PM   #505
jkuetemann is offline jkuetemann  Canada
jkuetemann's Avatar
zeoN,
I thought you had some of the Hitachi laterals on hand. Why not build a PeeCeeBee using those? The specifications between the old Hitachis and the newer Exicons are similar, I think if there is any difference in the sound it will almost solely be the result of slightly different manufacturing processes.
---Jason Kuetemann---
Power is only granted to those willing to lower themselves enough to pick it up.
Old 28th May 2013, 12:56 PM   #506
stoN_Cold's Avatar
Originally Posted by jkuetemann View Post
zeoN,
I am 54+ Y, don't have patience.
Obviously I'm stupid can't find
Regards zeoN_Rider
Old 28th May 2013, 12:58 PM   #507
AKN is offline AKN  Sweden
No snake oil
AKN's Avatar
PeeCeeBee Send a message via MSN to AKN
Lateral Mosfet
/ Anders
Old 28th May 2013, 01:15 PM   #508
stoN_Cold's Avatar
My mistake, I meant PCBs.
Regards zeoN_Rider
Old 28th May 2013, 01:37 PM   #509
jkuetemann's Avatar
OK, that makes sense now. It looks like nikosokey went the route I did and just hand produced a set. I am seriously thinking about having a small run done on the PCBs but haven't done the leg work yet to choose a board house to use.
Old 29th May 2013, 05:28 PM   #510
ivanlukic is offline ivanlukic  Serbia
@PMI and others searching for cheap DIY loudspeaker project for use with VSSA PeeCeeBee
I would personally recommend point source loudspeakers (coaxials). The cheapest that I found are projects based on Eminence Beta 10CX 10" woofer. Different projects with this woofer use different horn drivers. I plan to build Cheap Trick CT235 (from Klang & Ton) by Thomas Schmidt, but there are other projects even on this site (use search tool for Eminence driver Beta 10CX). One thing to remember is that with this kind of woofer a long time is needed to soften rear suspension on the woofer (it is made for sound reinforcement) so one should start break in before the enclosure is made. Play some FM interstation noise at couple of Volts level 24/7 for as long as possible. For US and Canada builders it is easy to obtain this cheap driver and suitable HF driver, but Beta 10CX is not available here in Serbia. I like CT235 project because it is floorstander but reflex port is tuned at around 60Hz which is good for people that has small room and need to place speakers near walls.
PeeCeeBeeHide this!Advertise here!
