PeeCeeBee
PeeCeeBee
Old 12th March 2013, 08:20 PM   #11
dobrivoje is offline dobrivoje  Serbia
I started to redraw peeceebee according to components I have in my drawer and found out that BD139 has wrong orientation. It must be reverted.
Old 12th March 2013, 10:21 PM   #12
shaan is offline shaan  India
shaan's Avatar
Indeed.
Pin orientation in TO126 devices like the BD pair is reversed from that of TO220 parts. So one needs to be careful, otherwise sharp clicks, chirps and pops will be heard.
Edit: in the silkscreen there are clear pin markers(c e for pnp vas and b c for npn vas) near the VAS bjts for avoidance of mistakes and to ease installation of either to126 or to220 parts, in case one opts for the latter.
Old 12th March 2013, 11:39 PM   #13
This is first variant of my peeceebee. It needs some more refinements.
I'm not sure if I can find small enough electrolytics for 35V supplies.
Old 12th March 2013, 11:58 PM   #14
de Ocampo is offline de Ocampo  Philippines
de Ocampo's Avatar
Nice work! Dobrivoje...
@ Shaan,
For ease of adjustment, is it possible to use v-trimmers in place of the offset resistors?
TY!
Old 13th March 2013, 12:45 AM   #15
No, no, I was not clear enough. It's my variant of shaan's peeceebee. I just moved some components to get space for big input cap and heatsinks for VAS transistors. I also tried to place all components on one quarter of Euroformat (160 x 100 mm) PCB. I'm still not satisfied, some tracks are too long, some components not at right places and yet shaan's peeceebee is better.
Old 13th March 2013, 01:02 AM   #16
naf is offline naf  Indonesia
Nice dovibroje!, I think 100nf input filter is 100pf
Old 13th March 2013, 07:06 AM   #17
shaan's Avatar
Originally Posted by dobrivoje
my peeceebee.
Looks cool. Which software are you using? I ask becaus my stupid-a** pcb making program lacks many popular models, like TO247/264. Thanks.
Shaan,
TY!
Of course. However, you wil need a 1Meg trimmer. Adding it to the board seemed to complicate the layout and increase board size by at least 10mm and demand two ugly jumpers. Aesthetix Lost.
It should be noted that without the off marked resistors it is possible to get an offset of less than 100mV. If this occurs then one only needs to connect a high value resistor(~220K) to either of the OFF marked spaces while keeping an eye on the millivoltmeter, this will ensure a very low and steady offset.
shaan
Old 13th March 2013, 10:24 AM   #18
@naf
You're right. It's 100p. My mistake.
@shaan
I use free drawing program Free Graphic Design Software – DrawPlus Starter Edition from Serif
It's not PCB software, it's plain drawing program.
Old 13th March 2013, 01:05 PM   #19
shaan's Avatar
Thanx.
Old 13th March 2013, 01:25 PM   #20
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
You will have to draw the new shapes yourself, but that's easy
You must have some instruction called "library add" or similar.
To know what they expect, put a similar component you already have (say, TO220) on the PCB and "disassemble" it, there must be some command which "turns it into primitives", which are the separate elements that make the symbol: pads, tracks, holes, labels, etc.
You draw your own in a similar way (remember elements will be in different layers) , select them, and add it to a library with a new name.
PeeCeeBeeHide this!Advertise here!
