PeeCeeBee - Page 163 - diyAudio
Old 16th July 2014, 07:55 AM   #1621
Shaan- sorry.Module is already sold.I had only one stereo version.pcb I built only for personal use.I already have built TSSA BIGBT.
still4given-Thanks...I do not understand your question.
Old 17th July 2014, 01:11 PM   #1622
shaan is offline shaan  India
shaan's Avatar
No Problemo. Happy listening.
Old 24th July 2014, 08:17 PM   #1623
Alguém poderia me ajudar? Montei esse módulo para substituir um C.I. STK mas estou tendo problemas. Fiz as seguintes modificações; estou usando como MOSFETs de saída o par IRFP240/9240 (não encontro os originais) estou usando o par de transistor BC547/557 no lugar do BC550/560 e os capacitores estou usando de 470uf ao invés de 1000uf, estou alimentando o circuito com 32+32Vno caso fiz uma placa só com dois canais (vide fotos) mas ao ligar o circuito a lâmpada série fica acesa direta indicando curto mas já revisei tudo. O que posso estar fazendo errado?
Could anyone help me? Rode this module to replace a CI STK but am having problems. I made the following modifications; 'm using MOSFETs as the output IRFP240/9240 pair (can not find the original) I'm using a pair of transistors in place of BC547/557 BC550/560 and capacitors am using 470uf instead of 1000uf,'m feeding the circuit with 32 +32 Vno case made ​​a plate with only two channels (see photos) but when you turn the lamp series circuit is lit indicating direct short but since I reviewed everything. What can I be doing wrong?
https://www.dropbox.com/s/9ya4qm30j5kzcvl/vssa.lay6
Old 24th July 2014, 09:13 PM   #1624
At first sight I see two mistakes:
1. BD139 must be reverted. I wrote about it at post #11.
2. You must use lateral MOSFETs. Their pins are G S D. Instead you used vertical MOSFETs with pins G D S. Verticals also must have temperature compensation and blah blah... If you can't find laterals, try Borys' version of VSSA with IRFP240/9240.
Old 24th July 2014, 10:50 PM   #1625
Our hesitation that I gave as the pinning of the mosfets, can not believe I did not realize it, our.
As for the original here in Brazil is not then have to replace some even with a little less quality?
Thanks Dobrivoje.
Old 25th July 2014, 01:06 AM   #1626
still4given's Avatar
I have been buying my MOSFETs from here.
2SK1058 N-Channel MOSFET 160V 7A
2SJ162 J162 MOSFET P CHANNEL 160V 7A
No issues at all.
Old 25th July 2014, 09:37 PM   #1627
Good night people. Correct the mistake of pinning of IRFP240/9240 and now the lamp did not light series so I called the direct source and noticed that the BDs heat a little. Tomorrow I will test with load. In my BDS are mounting with the correct pinouts despite the error in the layout, I noticed it before assembling and reversed them. For me here in Brazil is difficult to buy original 2SK/2SJ, freight is expensive because of import taxes and the product tends to be retained for up to 3 months in customs. Working with electronics here in Brazil is complicated government explores other.
Old 5th September 2014, 11:24 AM   #1628
Olá, CACABEST.
Os 2sk/2sj originais você pode comprar na Multcomerial.com, eu e alguns colegas compramos lá e temos nossos VSSA funcionando 100%.
Hi, CACABEST.
The original 2sk/2sj you can buy at multcomercial.com, me and some friends bougth them and we have our VSSA working well .
Old 8th September 2014, 04:17 AM   #1629
jkuetemann's Avatar
Question Any interest in professionally made TO-3 boards?
Firstly, shaan, I will understand if you want to have moderation supress this post. I mean no intrusion but I just did not feel a new thread was justified at this time.
I'm thinking of possibly ordering a small run of my TO-3 PeeCeeBee boards manufactured at a board house. The original 'reference' art is located in post #405 of this thread, located >HERE<. I have since done some minor housekeeping of the artwork but there are no truly significant differences.
This was spurred by a request for a set of gerber / excellon files from another board member. I'm just curious if there is enough interest to justify a small order. I still have some of my own TO-3 lateral MOSFETS and would like to make a few more of the PeeCeeBee with them. Since these will be professionally made they would have plated through holes, silk screen printing and no jumpers (I do realize the feature of top side copper isn't with shaan's original desire, but the art is fully functional as a single sided board using the bottom copper layer only).
PLEASE READ THE FOLLOWING CAREFULLY!
I do not want to soil this thread with requests for boards. This is not the place for me to conduct a group buy, I'm only interested in finding out if there is still interest in the TO-3 layout. Please send me a Private Message (PM) if you have any interest in participating in a group buy. If there is enough interest I will create a new thread in the appropriate area and arrange to order a modest quantity of boards. I will also need to know which input transistor pinout would be most in demand; there are two slightly different layouts to accommodate either ECB or CBE devices.
---Jason Kuetemann---
Power is only granted to those willing to lower themselves enough to pick it up.
Old 8th September 2014, 08:58 AM   #1630
shaan's Avatar
Originally Posted by jkuetemann View Post
...top side copper...
That much is no problem Jason.
One thing, your name on the layout seems to have an error. Other than that the design looks kool to me.
Keep up the good work. Wish you get lots of orders.
shaan
Copyright ©1999-2017 diyAudio
