PeeCeeBee - Page 109 - diyAudio
Old 29th August 2013, 02:09 AM   #1081
wenz is offline wenz  Philippines
wenz's Avatar
Originally Posted by jkuetemann View Post
Check out the thread here, despite its title the thread has produced various configurations including BJT options for outputs. It is based on the same basic structure as the original VSSA and PeeCeeBeee.
thanks a lot jkuetemann, you encourage me to built this amps.
Old 29th August 2013, 02:11 AM   #1082
PMI is offline PMI  United States
Originally Posted by wenz View Post
@shaan, Good day, is it possible to change FET to a transistor(C5200/A1943)? It's hard to find FET in my location. Thanks..
I ordered mine from Tayda Electronics
https://www.taydaelectronics.com/cat...esult/?q=2sk10
https://www.taydaelectronics.com/cat...sult/?q=2sj162
Old 29th August 2013, 07:51 AM   #1083
JOHN BALI's Avatar
Originally Posted by masood View Post
dear what secret formula
Hi Masood...
Use BD139-140 instead any higher speed transistor so no need any compensation caps.
Originally Posted by shaan View Post
Agh... what innovative speaker design John!
Congrats. You are the first to build the dual FET PeeCeeBee made of edible sweet solids.
Please upload the pdfs of layout, silkscreen and mask if you think we should eat... uuh.. build it too.
Again, what innovative speakers John, quite inventional haha...
The speakers just for fun has build it long time ago
So here the PDF but no value cos I don't have it
please send me PM if someone want the .dip file(I use diptrace)
board size : 100mm x 64mm
I need someone that build it too
Thank you, I wish you happy
peace & G B U
Last edited by JOHN BALI; 29th August 2013 at 08:00 AM. Reason: attachment not attached (missed)
Old 29th August 2013, 08:06 AM   #1084
shaan is offline shaan  India
shaan's Avatar
Hi wenz.
I think it is possible.
With CFP/Sziklai outputs the amp should produce good sound [with some extra care to prevent oscillation in the o/p stage].
All the best.
shaan
PeeCeeBee V1.1 PDFs, V2 PDFs,V2 Gerbers,V3 PDFs,V3 Gerbers
Old 29th August 2013, 08:24 AM   #1085
wenz's Avatar
Originally Posted by PMI View Post
Wow, but I cannot order it since my location is far from the city. II will try first using transistor that i mention above, if failed, then proceed to the original parts.
Hi wenz.
All the best.
shaan
I already have a DIY amps, all are TEF, I did not try CFP/Sziklai outputs,
maybe I will have to try CFP/Sziklai and modify it to TEF if CFP is working.
Old 29th August 2013, 08:53 AM   #1086
shaan's Avatar
Hi John.
Can you please repair the horizontal stripes in the layout?
Thanks.
Old 29th August 2013, 08:56 AM   #1087
shaan's Avatar
...I will try first using transistor that i mention above, if failed, then proceed to the original parts...
I hope none of your PeeCeeBee experiments fails.
cheers...
Old 29th August 2013, 09:24 AM   #1088
JOHN BALI's Avatar
Hi John.
Thanks.
sorry for that... but the PDF is fine...
here the corrected one (I'm not familiar with the "pdf/image printer" software )
peace & G B U
Old 30th August 2013, 02:51 AM   #1089
Default PeeCeeBee Brazil
hello, this is a PCB Everton's Brazil ... please suggestions, criticisms are welcome ... sorry my bad english ... thank you1150936_357074711090944_670857201_n.jpg
Old 30th August 2013, 01:31 PM   #1090
Default last version
Here the latest version, some tweaks and fixes. The spaces are great for those who want to use polypropylene capacitors, but can also be used small electrolytic capacitors.
Sorry if it's posted in the wrong location, please enter the correct location
Thanks.
Copyright ©1999-2017 diyAudio
