Can anybody help me? This amp oscillate at 10MHz? - diyAudio
Old 5th March 2013, 05:01 AM   #1
Default Can anybody help me? This amp oscillate at 10MHz?
Hello,
just in yesterday I have built and tested Lazy Cat’s latest symmetrical topology with variation of n-most only output. The amp has almost all aspects meet my expectation, except the S/R and oscillation.. I initially used 22pF Miller cap. And my first pair of IRF530 stayed for couple of minutes before it broke down silently, together with one driver B649AC. And then after I replaced the B649, I also increase the Miller cap to 50pF. Even though, another two pairs of IRF530 did not sustain for couple of seconds after power on. I finally increase the Miller cap to 120pF, this time the amp starts to sing. My PSU is +/-35v. It can give a 28Vp swing, which is not bad. However, when I view the waveform, I see an high frequency oscillation at around 10MHz. This oscillation appear only to the negative circle. Can anybody tell me how to fix this problem? As you see that the slew rate is already low, maybe increasing the Miller cap is not a good cure. Can anybody give me a hint?
PS. Oscilloscope images are attached. You can see in that the amplified triangular waveform there is an oscillation at about 10MHz.
Last edited by jazzclassics; 5th March 2013 at 05:05 AM. Reason: put image in post.
Old 5th March 2013, 05:08 AM   #2
oops, still missed on image. Attach again.
This is the amplified triangular waveform with oscillation.
Old 5th March 2013, 05:25 AM   #3
Electrons are yellow and more is better!
peranders's Avatar
First of all: Keep the wires to the output fets MUCH, MUCH shorter!
/Per-Anders (my first name) or P-A as my friends call me
PA03 LM4780 amplifier group buy, SIGN UP HERE for the group buy 0 boards left. 110 paid.
Old 5th March 2013, 05:53 AM   #4
djmiddelkoop's Avatar
the gate-stoppers (100R) should be as close to the gates as possible.
“Information is not knowledge Knowledge is not wisdom
Wisdom is not truth Truth is not beauty Beauty is not love Love is not music Music is THE BEST”
Old 5th March 2013, 07:47 AM   #5
I bet that is the reason. Whoever tested and designed it got much shorter wires.
Old 5th March 2013, 10:19 AM   #6
Thanks for your idea. Currently those wires are 13cm in length.
Old 5th March 2013, 10:21 AM   #7
Thanks a lot for your tips. I will try it and report back later.
Old 5th March 2013, 10:22 AM   #8
Thanks a lot for your tips. I will try it and report back later. .. Any more ideas?
Old 5th March 2013, 10:25 AM   #9
lineup is offline lineup  Sweden
lineup's Avatar
If still oscillation after you have attached gate resistors close to Gate,
then you can try 47pF for C3 and C5. (They are now 20pF.)
This will increase compensation and stability.
lineup
Old 5th March 2013, 10:32 AM   #10
I have seen such long connection wires as shown in the following SSA photo, but claimed to have no problem in hi-freq response neither issue with phase shift. Is there any other possibility with the amp that caused the oscillation?
10Mhz Oscilloscope for CD Player Laser Calibration oszkar Solid State 1 28th February 2013 05:35 AM
Pre amp oscillate smithomo Solid State 47 31st August 2011 10:31 AM
Buying 0~10MHz Spectrum analyzer, solutions and advice Frex Equipment & Tools 28 17th June 2010 04:29 PM
200w amp trouble (LM3886T) - one chip only wants to oscillate chris-man Chip Amps 12 31st May 2004 11:27 AM
Unique request: 10MHZ (-3db) pre-amp Gomer Solid State 3 24th March 2003 10:55 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright ©1999-2016 diyAudio
