Regulator with floating ground and speaker protection
Old 2nd March 2013, 09:23 PM   #1
PauloPT is offline PauloPT  Portugal
Send a message via MSN to PauloPT
Default Regulator with floating ground and speaker protection
I'm building a regulated PSU based on LT1083 positive chip regulators. There is no negative counterpart so I'm using two of these chips with floating ground. Everything looks great except the speaker protection circuit. It doesn't like my floating ground and doesn't activate the relay. The circuit is powered from the main transformer trough a resistor divider to drop the voltage. Could I solve the problem using a second tranformer only for the speaker protection and connect one of the secondary wires to the floating ground?
Thank you.
Kind Regards,
Paulo.
Old 2nd March 2013, 09:58 PM   #2
whizgeek is offline whizgeek  Ireland
On your protection circuit, you have ac inputs, with common ground. Is this the connection to the resistor divider?
This is whats upsetting the floating ground bit.
You only need to use the dc from one of the LT1083 regulators. +ve side as i presume the protection circuit ground is common to all the circuits.
Its only a few milliamps for relay current, so negligible loading. do you really need the 317 regulator?
Also is d4 good enough for relay current?
Old 2nd March 2013, 10:00 PM   #3
rodolfo is offline rodolfo  Mexico
maybe you should do it this way
is the same ground
Old 3rd March 2013, 12:10 AM   #4
I thought of that but I'll loose instant power off on AC loss.
Kind Regards,
Paulo.
Regulator with floating ground and speaker protectionHide this!Advertise here!
Artificial floating ground mhennessy Solid State 10 24th January 2015 08:58 PM
Floating or common ground? IsakAlexander Car Audio 8 9th November 2012 11:06 PM
Speaker protection and common ground ads2 Chip Amps 7 1st January 2011 11:42 PM
Floating ground power supply Theodore Julie Power Supplies 8 11th June 2007 10:54 PM
Floating Ground Adapter? geek883 Car Audio 2 2nd April 2006 07:26 AM
