Ic 221-241 ??
this is
Joined 2010
:eek: I do not think that the case of the same piece. This 221-241 is very old...
You may be confused by that generic image. There are 4 Google references to 221-241; 3 of them to a
Siemens DIP 8 flash memorywhich must be > 14yrs ago, since Siemens semi. became Infineon in 1999.
In the absence of any other DIP 8 references, and that this Siemens component is still on US aerospace
databases, I think you will have to accept that your pic. and description match is the only likely one.
