ultra performance amp - Page 8 - diyAudio
Old 2nd July 2013, 09:31 AM   #71
The output transistor becomes less Thermally stable as Vce rises.
Cordell gives an arithmetic procedure to predict the onset of this unstable voltage. Basically, you need higher Re values for higher Vce in both BJTs and mosFETs.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 12th July 2013, 09:48 AM   #72
400kg is offline 400kg  Turkey
Banned
Send a message via MSN to 400kg
Default scope caps and problem
positive portion of the output wave is problematic. why is this happening?
Old 12th July 2013, 02:33 PM   #73
Bensen is offline Bensen  Belgium
Bensen's Avatar
Have you set your scope at DC or AC input signal? When set at DC is could be that you are seeing a DC-offset on the output?
Old 12th July 2013, 02:53 PM   #74
Banned
Hi.My friend has made this measurements.The first picture is both ac as you can see on the top of oscilloscope screen. Amplifier's output is asymmetric.What can we do?
Old 12th July 2013, 06:44 PM   #75
Bensen's Avatar
I am just thinking out loud:
An error like this should normally be corrected by feedback, so, could it be caused by something out of the loop? For example the VI-limiter?
The scope picture is with 26v output signal, do you have the same error with smaller output voltages?
Could you measure again without the limiter?
Old 13th July 2013, 06:24 AM   #76
Banned
Hi
Mr. Bensen
you're right. I'll try again after removing the servo and protection circuit.
Old 19th July 2013, 04:03 PM   #77
Banned
amp is not the problem. there is the problem of oscilloscope calibration.
respects.
Old 19th July 2013, 07:12 PM   #78
Banned
Default NEW CONCEPT EXCELINEAR
a new concept of performance, no dc offset problem.
Old 20th July 2013, 06:12 AM   #79
alex mm is offline alex mm  Romania
alex mm's Avatar
..... Hmmm ,congrats as usual from you ,nice schematic , but have you built , or just simulated ? Off course a decent PCB it's needed .
Regards ,
Alex
Old 20th July 2013, 08:51 AM   #80
Banned
Hi, Mr. Alex,
Not tested yet.
I've tested in simulation.
Subject to change.
"The Wire" Ultra-High Performance Headphone Amplifier - PCB's opc Headphone Systems 2592 4th March 2017 08:12 PM
Group Buy: QRV09 Ultra High Performance Headphone Amplifier peranders Group Buys 75 24th March 2013 09:54 AM
Ultra high performance headphone amplifier QRV09 peranders Solid State 121 25th June 2011 08:10 AM
Ultra-High-Performance Headphone Amp TPA6120 as FrontEnd for Quad-303 Super- Triplet tiefbassuebertr Solid State 3 24th April 2011 05:35 PM
Ultra-High performance OpAmp-based MOSFET Power Amp tlf9999 Solid State 20 7th September 2005 09:41 PM
Copyright 1999-2017 diyAudio
