ultra performance amp - Page 7 - diyAudio
Old 11th April 2013, 11:10 AM   #61
sajti is online now sajti  Hungary
This is my amplifier, which use bjt input stage. 110W/8ohm output, with THD:0.0008% simulated.
And it contains the protection too.
Sajti
Old 11th April 2013, 12:34 PM   #62
Karl vd Berg's Avatar
Originally Posted by alex mm View Post
....... @Karl vd Berg for you ,and not only ,here in attachment , it's an updated PCB, rev 1.5 .....
Regards Alex.
Very nice!
The specs must outperform many stock amps??
Old 13th April 2013, 06:14 PM   #63
400kg is offline 400kg  Turkey
Banned
Send a message via MSN to 400kg
my pcb protoype
Old 16th April 2013, 09:13 AM   #64
Banned
Originally Posted by Ian Finch View Post
Thanks for the offer but I don't have need of SOA limiters (if that's what you refer to) in domestic amplifiers. Perhaps I should say that I couldn't sell hi-fi amplifiers if I declared that they were fitted with any type of them. I would agree that PA and instrument amps such as I have also built in small numbers, do need limiters because the average output levels, operating stresses, abuse and risks are relatively much greater. I've been fitting dual and multislope SOA protection to these amps for quite some years because I have seen the damage caused by failures in them and the frequency with which it occurs. If your paper discusses something non-invasive and radically different in operating mode to dual or multislope limiters, I would be grateful to see it.
Actually, a properly designed SOA protection circuit should be inert when not invoked. Send me mail and I'll send you article on how to design them properly.
Old 30th June 2013, 09:18 AM   #65
Banned
Default completed module
finished module
Old 30th June 2013, 09:40 AM   #66
Yes.
A properly designed IV limiter or SOA protection MUST allow all valid signals to pass to all valid loads.
If one has an 8ohms speaker as the load and that particular speaker demands 30Apk on very rare occasions, then the amplifier that is used with that speaker should allow that 30Apk to pass to the speaker without the limiting interfering with the quality of the signal.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 30th June 2013, 10:46 AM   #67
Banned
Vtech audio Sapphire Amplifier - YouTube
Old 30th June 2013, 08:17 PM   #68
Bensen is offline Bensen  Belgium
Bensen's Avatar
Hi 400kg,
I see you are using 0,1R emitter resistors in the ops with three pairs of 2922/1216. I would like to use 0,1R or 0,15R for the same devices but with four pairs in parallel. With these values I can run the ops with 0,133 to 0,18bias current/device, this to achieve a nice class A output power.
But these values are looking rather small compared with other amp's using other output devices!?
Do you have any idea if the LAPT technology used in these Sanken devices are beter suited to use with rather low emitter resistors?
Any info is welcome!
Old 1st July 2013, 07:47 AM   #69
Cordell did a piece on output device Thermal Stability.
Maybe the Cordell interviews - outputs Thread.
regards Andrew T.
Old 1st July 2013, 06:35 PM   #70
Bensen's Avatar
Thanks for the hint Andrew! We mostly forget to check the available documentation.
Douglas Self goes relative far into detail concerning the emitter resistor value in an ops.
I'll start with a 0,1R and see if I get it thermally stable.
Greetz
"The Wire" Ultra-High Performance Headphone Amplifier - PCB's opc Headphone Systems 2592 4th March 2017 08:12 PM
Group Buy: QRV09 Ultra High Performance Headphone Amplifier peranders Group Buys 75 24th March 2013 09:54 AM
Ultra high performance headphone amplifier QRV09 peranders Solid State 121 25th June 2011 08:10 AM
Ultra-High-Performance Headphone Amp TPA6120 as FrontEnd for Quad-303 Super-ß Triplet tiefbassuebertr Solid State 3 24th April 2011 05:35 PM
Ultra-High performance OpAmp-based MOSFET Power Amp tlf9999 Solid State 20 7th September 2005 09:41 PM
Copyright ©1999-2017 diyAudio
