ultra performance amp
Old 28th March 2013, 06:20 PM   #11
alex mm is offline alex mm  Romania
alex mm's Avatar
Default PCB rev 1.2
......have layout again , find some errors , corrected and revised
Regards Alex.
Old 30th March 2013, 06:50 AM   #12
sajti is online now sajti  Hungary
Looks nice, as always Alex!
I'm working on my version, with bjt input stage...
Sajti
Old 30th March 2013, 07:23 AM   #13
SSDIY is offline SSDIY  Hong Kong
Regards Alex.
Hi Alex
Very nice pcb layout. But I have a question. There are 8 transistors laying under the pcb, 8 transistors x 3 leads = 24 leads have to insert to the pcb before soldering. Is there any way to make sure it has no problem when inserting the leads through the pad holes?
I have designed some similiar pcb layouts but keep wondering if there will be any problem to insert the leads of transistors into the pad holes on the pcb.
Old 30th March 2013, 07:45 AM   #14
Walkalone is offline Walkalone  Viet Nam
Very nice layout, Alex.
Your PCB layout skill is great!
Old 30th March 2013, 10:21 AM   #15
alex mm's Avatar
Hi SSDIY,
First you can insert , each transistor in position , solder each , and after mount pcb to the heatsink , ofcourse not so easy but with some skill you can do the job Thanks for kindnes .
Regards Alex.
Old 30th March 2013, 11:40 AM   #16
coolet is offline coolet
coolet's Avatar
make a metal or galvanized sheet pattern.. for me i cut a hole enough to mount the transistor.
Old 30th March 2013, 12:15 PM   #17
AndrewT is online now AndrewT  Scotland
Solder just ONE lead of each output device. Maybe to just one side of the pad rather than all round.
This holds the transistors roughly, but not rigidly, in place.
Bolt or clamp to your heatsink.
Then when all is correctly aligned, re-solder that first lead to release any strain on that part soldered leadout.
Finally solder all the other leadouts.
regards Andrew T.
Old 30th March 2013, 12:43 PM   #18
coolet's Avatar
that is good if your pcb has plated through hole
Old 1st April 2013, 04:59 PM   #19
alex mm's Avatar
Default PCB rev 1.3
.......few mistakes ,revised again , better ground layout etc .
Regards Alex.
Old 1st April 2013, 05:20 PM   #20
michaelkiwanuka is offline michaelkiwanuka  United Kingdom
Banned
This amp doesn't have safe operating area protection; short the output and you have one dead amp.
ultra performance ampHide this!Advertise here!
"The Wire" Ultra-High Performance Headphone Amplifier - PCB's opc Headphone Systems 2609 12th November 2017 07:49 PM
Group Buy: QRV09 Ultra High Performance Headphone Amplifier peranders Group Buys 75 24th March 2013 10:54 AM
Ultra high performance headphone amplifier QRV09 peranders Solid State 121 25th June 2011 09:10 AM
Ultra-High-Performance Headphone Amp TPA6120 as FrontEnd for Quad-303 Super-ß Triplet tiefbassuebertr Solid State 3 24th April 2011 06:35 PM
Ultra-High performance OpAmp-based MOSFET Power Amp tlf9999 Solid State 20 7th September 2005 10:41 PM
