Output inductor in power amps - pro and con
Old 26th February 2013, 12:26 PM   #31
ivanlukic is offline ivanlukic  Serbia
It is reported more than once that application of output inductor may lead to higher distortion and less (!) stability with some amps. I remember that some John Linsley Hood amps disliked it and Alexander current feedback amp deliberately avoided using it because he noted that harmonics are more pronounced. Also, Rod Elliott's P3A with CFP output stage dislikes output inductor.
Old 26th February 2013, 12:34 PM   #32
dadod is online now dadod  Croatia
dadod's Avatar
Its not that JLH amp disliked output inductor, just JLH used output resistor instead and thus decremented a dumping factor.
Old 26th February 2013, 12:50 PM   #33
Bonsai is offline Bonsai  Europe
I think an output resistor is totally sub-optimal.
Old 26th February 2013, 01:02 PM   #34
There is an interesting paper by Ben Duncan: "White Paper: A New Zobel Network for Audio". It is published in 2009 and is (probably still) available at Russ Andrews Accessories site.
Old 26th February 2013, 01:04 PM   #35
Dadod,
JLH designed many amps. The amp that showed some instability with output inductor was one of his MOSFET amps.
Old 26th February 2013, 01:05 PM   #36
dadod's Avatar
JLH used 0.22R only and I like the sound of that amp.
Old 26th February 2013, 01:11 PM   #37
dadod's Avatar
Dadod,
Do you mean this amp? I never used it with output inductor so I can't tell.
Old 26th February 2013, 01:13 PM   #38
magnoman is offline magnoman  United States
As a big believer in the devil is in the details I really enjoy threads like this, thanks.
I think that one needs to determine for themselves what additional circuitry if any is needed and why. In my case I became interested in trying to better understand why emitter followers can oscillate and found "Why Circuits Oscilliate Spuriously, by Dennis Feucht" to be a good read (in addition found that you can model negative impedances such as -R in LTSpice). In an example amplifier I am looking at, such oscillations can take place when there is a load capacitance between 50p and 4000p (when parasitic inductances are added especially to the output transistor base). At which point combinations of rc's and L's and base stoppers can be used to tame such oscillations (and remove resulting resonances). Dave, not 100% certain but having an R immediately on the emitter followed by the rc would be my first guess at the better solution.
I have seen mentioned numerous times that simulating a nearly full scale sinewave can bring on such oscillations, and that an even better approach is to add a small square wave pulse train to the sinewave. What I have found is that that changing the rise/fall times of the pulse can also make a big difference, especially if these times are made longer, closer to the equivalent bandwidth.
Bonsai, for the case described above I dont see any difference in the main loops phase margin, although there can a difference in gain margin especially if you run the ac sweep with various dc inputs (bias the amp output closer to a rail).
-Antonio
Old 26th February 2013, 01:45 PM   #39
dadod's Avatar
My TT-amp simulated with a small square wave pulse train to the sinewave.
Old 26th February 2013, 03:13 PM   #40
davidsrsb is offline davidsrsb  Malaysia
Originally Posted by Bob Cordell View Post
Hi davidsrsb,
I seem to recall higher values in the early 70's on several amps, perhaps as high as 4uH, but values declining over the years to 2uH or below. I used 0.5uH on my MOSFET power amplifier in 1983.
For me, less than 0.5uH of isolation gets scary and seems insufficiently effective.
Bob
1uH is 0.12 Ohms at 20 kHz so I suppose it is already low enough not to disturb the frequency response across the audio band. There is no point in trying to push for even lower values.
Output inductor in power amps - pro and conHide this!Advertise here!
How much power is Needed? Multi Channel vs Pro Amps hawkson Class D 6 4th May 2011 12:59 AM
Best inductor for pro preamp bob123 Parts 1 1st June 2010 11:34 PM
Quad II power amps......power output transformers!!! bwes87 Tubes / Valves 3 10th September 2008 02:20 AM
Output Inductor Power Requirement gearheadgene Class D 6 28th February 2007 03:47 PM
Pro & Con of regulated P.S in Aleph series? ghee0 Pass Labs 0 21st August 2001 02:30 AM
