Audio Power Amplifier Design book- Douglas Self wants your opinions - Page 38 - diyAudio
Old 31st March 2013, 11:11 PM   #371
Waly is offline Waly  Uzbekistan
Waly's Avatar
Originally Posted by Bonsai View Post
Nonsense. The two are not the same, and TPC is clearly inferior to TMC.
You obviously missed some late discussions on this topic.
Let me put it this way: show me a TMC compensated amp and I'll give you back a TPC compensated version with exactly the same performance metric (loop gain, phase margin, etc...)
It was mathematically proven that TMC is equivalent to TPC plus a lead lag phase correction. Yes, TMC could be considered as a more simple and straightforward 2nd order compensation method compared to TPC, but to claim that TMC is superior in any other way shape or form, that's totally incorrect.
Old 31st March 2013, 11:23 PM   #372
Bonsai is offline Bonsai  Europe
Bonsai's Avatar
No.
bonsai
Amplifier Design and Construction for MUSIC! http://hifisonix.com/
Old 1st April 2013, 07:06 AM   #373
I assume you refer to the work by the esteemed "Megajocke"?
This is a very ingenious analysis but not a mathematical proof.
It is based on approximations such as that the IPS has infinite bandwidth and no phase shift.
Probably more important is that it considers only transfer function and not what Bode called "sensitivity" (I think it would be better called desensitivity since it is the factor by which the sensitivity is reduced).
Usually the Return Ratio and the (de)sensitivity are equal but this is not inevitable, which is precisely why Bode created the two distinct terms.
I think they are not equal in this case and that TMC can do better on this metric.
But I would like to learn more. Perhaps after criticism of Mike's repeated assertions without evidence, now Bonsai can contribute his own analysis?
Best wishes
David
Old 1st April 2013, 09:33 AM   #374
Originally Posted by Esperado View Post
I will just add that, in all analog mixing desks i had modified, there is a great improvement, in the mixing bus input stages, to swap to current feed-back OPAs.
A number of people noticed great improvement when CF opamps are used for summing amplifiers in mixing consoles.
Old 1st April 2013, 09:59 AM   #375
Bonsai's Avatar
Best wishes
David
Why? Why? Surely I can also just go on pounding away, saying that I am right and then I will have proven my point! Or, do I really have to get busy on the simulator?
bonsai
Old 1st April 2013, 11:24 AM   #376
Banned
A monologue with the occasional word in bold does not constitute proof, as of course we are seeing in that other discussion.
Now, repeat after me
TPC does not equal TMC
TMC is better than TPC
VFA does not equal CFA
CFA is great for audio
He who knows not and knows not that he knows not is a ......
Old 1st April 2013, 12:20 PM   #377
Bonsai's Avatar
Positively Rumsfeldian.
bonsai
Old 1st April 2013, 12:48 PM   #378
Banned
...show me a TMC compensated amp and I'll give you back a TPC compensated version with exactly the same performance metric (loop gain, phase margin, etc...)
True!
Old 1st April 2013, 01:10 PM   #379
Waly's Avatar
A Canadian good friend of mine (but not so esteemed here) reached exactly the same results using a star-triangle transformation of the TMC feedback network. Now, if that's not mathematical proof, then I don't know what that is.
In fact, my offer to provide a TPC version with exactly the same performance metric is based on his work. Calculating the equivalent TPC network RC values takes about 5 minutes.
Old 1st April 2013, 01:48 PM   #380
...friend of mine ...reached exactly the same results using a star-triangle transformation of the TMC feedback network. Now, if that's not mathematical proof, then I don't know what that is.
A star-delta transform seemed more robust to me too, so that's what I used myself.
But our results, or perhaps interpretations, seem to differ a little. Can you post your friend's results?
...my offer to provide a TPC version with exactly the same performance metric is based on his work. Calculating the equivalent TPC network RC values takes about 5 minutes.
A worked example would help too, can you post one?
Best wishes
David
PS. Nice to read a post with a hint of actual substantiation.
The design of active crossovers- Douglas Self wants your opinions DouglasSelf Analog Line Level 293 20th May 2016 11:33 PM
Comments on Audio Power Amplifier Design Handbook by Douglas Self Samuel Groner Solid State 68 16th March 2013 10:26 PM
Douglas Self's Active Crossovers book forr Analog Line Level 8 31st December 2010 05:20 PM
New Douglas Self Book blmn Solid State 7 22nd July 2009 06:00 PM
book-audio power amplifier by Douglas Self mikee12345 Solid State 8 16th November 2003 01:16 AM
Copyright ©1999-2017 diyAudio
