Audio Power Amplifier Design book- Douglas Self wants your opinions
Old 1st November 2013, 06:27 PM   #2151
FredsBands is offline FredsBands  United States
This is quite the book, just saw it on Amazon.
Old 1st November 2013, 09:50 PM   #2152
Bob Cordell is offline Bob Cordell  United States
Originally Posted by nigel pearson View Post
Measured the Hypex SMPS 400/180 . Not the quietest of devices . Made an RF probe and found the fuse end to be quietest . 3 cm is the optimum minimum spacing . Good news is the RF didn't carry up the mains cable .
As I understand it the Hypex PSU is not fixed voltage . It tracks the mains voltage . Rather a shame because I want to try an optimum class H design . I do see 48 V switch-modes now . That would be ideal . My brief look at this says to me that the Hypex 180's deserve a conventional PSU . Mine I have been trying is 500 VA only as it was what I had handy . I suspect 160 VA would power a pair of UCD 180's if the Hypex 1/8 crest factor and 92 % efficiency rating is factored in ( less if space requires it ) . From my measurements that would even allow continuous 70 Wrms if heat-sinked on a biscuit tin or better . I would suggest 0 -25 0 - 25 transformer as a excellent choice if so . I used 2 x 22 000 uF . I was testing on a piece of 2.6 mm aluminum about the size of A4 paper . Slightly more as it has 70 mm right-angle folds at each end with no side pieces . Even after 15 minutes at 70 W rms the heat build up was fine .
Anyone know of a simple cheap temperature switch ( over temperature ) . The ones Naim audio used need high current , I don't trust a toaster switch to work at uA . If the toaster switch ran a 5 V relay at 70 mA I guess that might be OK ? It could have a shunt resistor to help . I guess a thermistor and comparator might be OK ? It would switch the 12 V logic of the modules . 0V = ON .
Try the TI/National LM35 Centigrade temperature sensor in the TO220 package, which is convenient for mounting on a heat sink.
Bob
Old 1st November 2013, 10:07 PM   #2153
While on the subject of class D, it is important to recognize that class D amplifiers fall into the category of a sampled-data system. Whether the class D is PWM or PDM (e.g., Delta-Sigma), the analog input signal is sampled at only discrete times. As such, in principle, class D amplifiers should include an anti-alias filter. This filter must have high attenuation at one-half the lowest sample rate and higher frequencies. Some PWM modulators can have varying carrier frequencies (sample rate) with signal, and sometimes the sample rate can swing to a lower-than-expected frequency. Many SACD players can produce significant levels at ultrasonic frequencies. Moreover, unwanted EMI sources can fall in a frequency range where aliasing may occur as a result of the class D sampling process.
Bear in mind that the D in class D does not stand for digital, but is just the next letter in the alphabet after class C. Even though class D is not digital per se, it is a sampled-data system.
Bob
Old 4th November 2013, 12:29 PM   #2154
franzm is offline franzm
Originally Posted by kgrlee View Post
Could you post a pic for those of us beach bums who only have older versions and are too indigent to buy the latest?
Fig. 7.44 and 7.45 in APAD3&4, pag.230-235. No pics. They're copyrighted.
Old 15th January 2014, 04:40 AM   #2155
Esperado is offline Esperado  France
Banned
I don't understand.
What is the difference in nature between an analog tape recorder, where the signal is a polarisation frequency modulated in amplitude by the analog audio signal, and a class D amp, where the signal is a square wave modulated in step duration, analog way - means continuous, no step- by the audio signal ?
Of course, both need to filter the analog signal to avoid beats with the switching/polarization frequency.
Old 15th January 2014, 11:50 AM   #2156
nigel pearson is offline nigel pearson  United Kingdom
Originally Posted by Esperado View Post
I don't understand.
Tim de Paravacini say they are mostly the same . The magnetization taking place at the top and bottom of the bias wave . He went on to say if people had thought about this the 200 kHz bias frequency would have suggested the 192 kHz sampling that eventually became the true hi fi standard . The big advantage of class D and tape recorders is they don't need decoding . They are ready to eat so to speak . The only digital I strongly dislike is CD . Others systems claim less or give more . CD I suspect is dogged by the method of storage and playback and not 16 bit linear quantization . Early digital LP's seem better ( no , not colouartion or my ears , just better from the same master ) . Donald Fagen The Nightfly for example made on the 3M machine . Very glassy , not horrible because of it . In fact not unlike the Hypex UCD 180 . It is said to deliberately have 44.1 kHz sampling running from a 48 kHz master doesn't help . The LP will be one stage better in that . Also the timing errors are one off errors . The cutting of the LP is not without problems . At least errors are of a different origin . Some overlap .
From a suggestion made to me earlier in this thread the need for oscillator stability in class D is perhaps the Elephant in the room . I doubt it is a problem if COG caps ( 30 ppm typical ) are part of the RC devices . One thing I do not understand about Hypex is why the Hypex SMPS is not locked together with the amp . This must be a free lunch that has not been accepted ?
Old 15th January 2014, 12:05 PM   #2157
Ouroboros is offline Ouroboros  England
Ouroboros's Avatar
But the Hypex amps (both UCD and nCORE) vary in switching frequency all the time, as the switching frequency drops as the signal instananeous amplitude increases. It would be very foolish indeed to lock the SMPSU to this!
Old 15th January 2014, 12:17 PM   #2158
Banned
Agree on all this, Nigel :-)
About CD, i believe the mistake is that the standard use "flux" and not pure datas (that you could sample and re-clock) with a poor error correction system.
And optical disk very fragile. 44.1Khz is too low, too.
Well, i quite enjoy the Ry Cooder's Bop t'ill you drop CD (one of the first digital recordings), despite all the evils ;-).
Old 15th January 2014, 01:42 PM   #2159
I don't understand.
Hi Esperado,
Are you saying that an analog tape recorder is a sampled-data system?
If so, are you saying that it is due to the recording bias signal and that the effective "sampling rate" is the frequency of the bias oscillator?
Bob
Old 15th January 2014, 03:39 PM   #2160
I wonder ? The frequency doesn't seem to vary much . I seem to remember about 390 kHz to about 405 kHz . I didn't really look that carefully . As I was measuring spot frequencies maybe I didn't see what I should have if using music .
The point made to me earlier in this thread was that sub harmonics can not exist where the oscillator is stable . That seems reasonable to me . I am reasonably happy to believe the inherent stability of Hypex is good ( espeailly in a small time window ) . If it varies it is to accommodated it's way of working . Thus it might produce sub harmonics . However at a very high frequency . I still see locking the PSU to the output stage as helpful . If it is identical it can not beat or hetrodyne ? That stimulates a though . Sub harmonics always seem to plague radio so why not class D ? I did see stuff . Alas it was very hard to say if it was generated in my home brew output measuring filter (12 pole - 3dB 50 kHz ) ? It got much worse with SMPS attached ( other was 500 VA + 2 x 22 000 uF at 42 V ) .
Audio Power Amplifier Design book- Douglas Self wants your opinionsHide this!Advertise here!
The design of active crossovers- Douglas Self wants your opinions DouglasSelf Analog Line Level 293 20th May 2016 11:33 PM
Comments on Audio Power Amplifier Design Handbook by Douglas Self Samuel Groner Solid State 68 16th March 2013 10:26 PM
Douglas Self's Active Crossovers book forr Analog Line Level 8 31st December 2010 05:20 PM
New Douglas Self Book blmn Solid State 7 22nd July 2009 06:00 PM
book-audio power amplifier by Douglas Self mikee12345 Solid State 8 16th November 2003 01:16 AM
Copyright ©1999-2017 diyAudio
