Detex Audio 741 ic based low component count NICE SOUND
warm regards andrew lebon
[image] [/image]"It's Better to try and fail than to never know and always wonder"
#2 |
if its the original 741 op amp, this is not suitable for audio, there are much better ones, for little money. Makes one wonder how any designer could use a 741 for audio these days.
Can't see how its a nice sound, have you listened to it? |
#3 |
Care to share or link the schematic?
Thanks. |
#4 |
The advantage of a 741 is that can be swapped by a 5534
that will greatly improve the sound audibly speaking , i guess that the eventual customer will at least experiment a valuable and encouraging upgrade that will actualy work. |
#5 |
My daugther still use it playing guitar.
35 watts RMS at 8 ohms..... aprox. ... and almost 20W at 8 ohms. Sounds good... stérile as chip amplifiers...but it is compact and simple. I really do not remember if i have made modifications.... this is simulator..sometime real life we have to adjust something..for instance, the zener current not to overheat.... these details. Nice toy to build in a weekend. regards, Carlos |
#6 |
I think you must have made something else, because this amp, as is, is terrible.
It has +/-35V rails but the Op Amp can not swing more than 12V peak each way. You are wasting 20V each side. It's also overbiased and not compensated, so it will self destroy thermally. Plus other small details. |
#7 | ||
Indeed, there is a classic CFP design using a very slow uA741, and it sounds nice. Well, why not show me your favorite simple CFP driven by 5534 or better opamp? |
#8 |
pictures dont LIE hottest selling kit now
#9 |
Trying to finish 2sc5200 version with enitter resistors
#10 |
Dear andrewlobon,
Are the range of Detex Audio products available in India? Can you provide an address or Tel No? --gannaji
www.samritatrust.org |
| First amp I ever built - An excellent simple class A amp for begginers | monty78pig | Solid State | 0 | 28th November 2012 05:12 PM |
| Simple high quality audio amp using tip41 & tip42 | rrbadrike | PA Systems | 0 | 27th March 2012 08:45 PM |
| Yamaha Amps & Simple Killer Amp... | bhostinsky | Solid State | 4 | 12th January 2011 09:44 PM |
| Build a Loud, Simple & Cheap amp for a friend | EWorkshop1708 | Car Audio | 5 | 19th April 2008 04:53 PM |
| Good & simple chip amp for 2-ohm load? | Otherwise | Chip Amps | 7 | 8th July 2003 07:21 PM |
