#81 |
the main virtue is a _true_ galvanic isolation between console and dozens of effects. Inserting the effect in one line can cause hum and crosstalk in completely independent line. I was confronted with such problems. The explanation is on Jensen site:
http://www.reed-electronics.com/ednm...98/12df_03.htm http://www.reed-electronics.com/ednm...98/12df_03.pdf |
#82 | |||
I think this is a myth. I did some comparing spice tests with differential inputs. Lownoise JFETs vs. Lownoise BJT. Note: My test used ONLY input pair, with collector resistors. They were tuned to do exactly same AC current job. for example: 5 uA current AC output across 1 kOhm resistors or 5 /50 mV ac across same resistors. This means - open loop - one transistor base/gate tied to GND - the other fead with a few mVolt input I did tests without Emitter/source resistors. In this case I adjusted mV input, to do same job across collector load ( BJT had like 4-5 higher gain than JFET. uA AC current / mVolt input ) The THD harmonics ( 2nd + 3rd ) was at very similar level of magnitude. At same job done. Quote:
But actually this was so in my test. I also tested with same input level: 1mV / 5 mV In this case I adjusted with Emitter/Source resistors to get equal job done. Of course the bipolar in this case can afford more resistive degeneration as they have like 4-5 higher AC current output per milliVolt AC in. This gave like 12 dB lower level distortion than JFET pair. ( -149 dB vs. -137 dB ) At same level in, same collector job done. ======================= Quote:
Also we have low bias current and DC Output offset to consider, many times. Lineup ---------------------------- Attachment. 2SC2240, The Fourier result.
lineup |
#83 |
You will find a thesis on exactly the same subject Audio Frequency Noise Characteristics of JFets AN74-4 by Siliconix. JFet design catalogue 1983! Also composite Op-Amp for high performance AN81-3.
Unfortunately both no longer in print. I have no software means for copying/ sending both articles. richj |
| Making a bipolar cap | weinstro | Parts | 7 | 13th May 2009 03:35 PM |
| Regulated Power Supply. Bipolar, JFET or MOS? | Kenneth Zhu | Tubes / Valves | 4 | 30th December 2007 09:30 AM |
| Can I replace BF245C JFET with J201 JFET? | bigmike216 | Parts | 2 | 7th December 2005 07:50 AM |
| Jfet/bipolar PCB and Schematic (finaly) | sonnya | Solid State | 35 | 31st October 2003 03:39 PM |
| How does this bipolar look? | punchpeanut | Solid State | 11 | 2nd October 2003 08:48 AM |
| Page generated in 0.08105 seconds (79.25% PHP - 20.75% MySQL) with 11 queries |
