Old 5th December 2003, 11:24 AM   #71
Terry Demol's Avatar
Originally posted by rickpt
This can be partially dealt with a cascode...
As has the 627 in its front end, amongst other advanced
tricks to reduce thermal feedback induced distortions
common on most opamps.
for me those are just a subjective comments and doesn’t mean a thing, some like apples, others like oranges...
Remembers me one talk I had with a friend that is the Meyer Sound loudspeakers importer for Portugal, they had one model that had one type of compression driver that generated a lot of distortion because of the used topology of the horn, but people seamed to like very much that speaker wen they first listened to it, because of it's rich highs
As you can see the ear can be easily tricked...
"Rich" to me means distortion but nice distortion. It has it's
place. It doesn't mean "transparent". I think both can be nice
but are very different.
WRT my comments about 627:
Mark Levinson uses the 627 as I-V in the flagship 30.6 dac, Sonic
Frontiers offered it as the top upgrade for their kit dacs. Most
aftermarket modifiers offer it as an upgrade for typical opamps.
It is widely used in many hi-end products for critical locations.
Maybe you could even do a search on DIY audio and see how
many people have tried it with great success.
I did listening tests which formed my initial opinion. I let others do
the same, they came to same conclusion. I did research on the
net and found most others had the same opinion.
When you have groundswell of like opinion from many sources
that are unbiased that is a good indication that your own
results are close to the mark. I can go on about methods,
equipment, topologies, etc suffice to say my comments are
not based on singular unsupported events. I am careful not
to do this on internet as it adds to misinformation.
Also it is a very expensive device, no one uses it unless
there are real sonic advantages, and this is why it is never
in pro gear.
There are only 2 SSL consoles that I know of, in Portugal and are both 4000 series, and pretty old by now, so I really cant answer that question but there is the SSL 9000 preamp schematic floating around the web and uses the NE5534 and MAT02...
Here in Portugal we have a pretty small music market and it isn’t easy to rentable such an expensive console.
All sound engineer I know say that those mixers sound great, and almost all studios around the world has a SSL4000 console, if its so bad why it is still used?
Lots of people love the sound of early SSL's especially
when they slam the master buss compressors, it is a rock & roll "sound" , however it is a long way from transparent. The SSL
is king of flexibility, automation, total recall and ease of layout. It
is very powerful.
However most audiophile type engineers prefer the Amek 9098,
API discrete, Neve and other consoles for their more open sound.
This is one of the main reasons SSL introduced the 9000J series
and now the K series, to compete with these products
Lucasfilms Skywalker director of music Leslie Ann Jones sums it
up well in the 4th last paragraph "for us....
http://emusician.com/ar/audio_agony_ecstasy_choosing/
I custom build electronics for direct to stereo recording and NO
console or mixing in process.
So I'm coming from a different level of performance compared
to most engineers that just mic it all up and run the faders up.
But for rock and roll you need the power and flexibilty of a
huge desk with its 100's of opamp stages.
Not for me.
Terry
Old 5th December 2003, 11:42 AM   #72
in pro gear.
I must clearly be misunderstanding you here Terry??
The only conclusion I can draw from that sentence is that
there is no real sonic advantage to the 627, but that seems
to contradict yourself having spent three previous
paragraphs telling how good it is. Could you please clear
up my confusion.
Old 5th December 2003, 12:02 PM   #73
up my confusion.
To clarify,
Have a look at most pro gear and compare the cost to hi-end
gear. Work out how much that gear is rolling out the factory
door (divide retail by around 4).
The 627, being possibly the most expensive audio opamp
available is finacially unviable in most of this gear.
The exceptions are stuff like cranseong / avalon etc but
these designs are discrete anyway... but that's another
story....
gotta go, tonight I'm actually playing some music (gtr) for a
change, tech hat is officially off.
T
Old 5th December 2003, 12:24 PM   #74
To clarify,
story....
T
OK, so the problem is that pro-gear is more cost-sensitive
than I thought. Well, thinking of it, for a megachannel mixing
console it would be quite a lot of money, of course.
Old 5th December 2003, 06:47 PM   #75
Geoff is offline Geoff  United Kingdom
Terry
You have said:
"We have compared 5534 vs 627 in DAC I-V, as stated before
the 5534 is a bit slow for this application, the 627 was way better."
and:
"Mark Levinson uses the 627 as I-V in the flagship 30.6 dac, Sonic
It is widely used in many hi-end products for critical locations."
How does this correlate with TI's recommendation for their recent 24bit 192kHz dac chip, the PCM1792? The datasheet for this dac recommends using the NE5534 for I/V conversion. Given the selection of in-house op-amps from which to choose (including the OPA627), they must have a very good reason for this recommendation.
I would have expected a bias towards the more expensive (higher profit margin) devices in their portfolio so the NE5534 would appear to have a significant advantage over the OPA627 in this circuit. TI/BB have recommended the OPA627 for I/V conversion in earlier publications, so there must be an explanation for this seemingly (to some) retrograde step.
It is also interesting to note that TI have recommended a Linear Technology op-amp for the differential circuit, so presumably their selections have been made on performance grounds rather than cost/profit.
Geoff
Old 5th December 2003, 06:56 PM   #76
Account Disabled
Geoff
I am pretty sure that TI/BB knows about their devices, and electronics in general a lot less than ur arm-chair designers here.
Old 5th December 2003, 07:29 PM   #77
To those who do not like the Null Test Method.
As I recall this is the method Bob Carver used in is legeandery Stereophile Amplifier challenge.
For those unfamilar with the story (about 15 years ago) Bob Carver was able to make one of his "un-audiophile quality" solid state amplifiers sound like an audphile's reference tube amp, a Conrad Johnson P-P 65 W/Ch tube amp. He was successfull and the tool used was the Null test mentioned and maligned by some previously.
One channel of the C-J was one amp, the Carver was the other. Bob then tweeked the Carver until there was no sound coming out of the monitor speaker. This method allowed him to duplicate the C-J's transfer function. This made the Carver amp sound (some might say distort) identical to the C-J amp.
Sounds like an example of a uselful testing tool to me.
Aud_Mot
Old 5th December 2003, 08:28 PM   #78
richwalters's Avatar
So far the forum has discussed various chip merits, however as I worked with Neve in the mid to late 80's, we always used transformers as the in & out interface, and never raw signals direct to any mixer or line input, even if balanced. Naturally the studio's wanted the best quality and they got it regardless of the quantity of transformers was used.. The R. Neve legend remains electronically superb to the day.
The electronically balanced input configuration was never used in Neve consoles, mixers or ISA discretes. The secret probably lay in those lovely transformers; the subject and technical content of which and the EQ is still copyright protected. So to assess subjective sound off the bench without a similiar setup is prone to so many errors.
rich
Old 6th December 2003, 02:45 AM   #79
Banned
Default TI may own B-B, but......
As I understand it, the digital audio group is based in Japan, so who knows what those guys listen for.
Maybe it is just their way of saying that TL071s suck.
And as for transformers......
If I was building something with lots of op-amps, that were susceptible to RF and stuff, I would transformers to keep as much of it as possible out. Not a bad idea.
Jocko
Old 6th December 2003, 07:35 PM   #80
Neve's philosophy works......nobody copied it before they found out it was too late.........in the meantime most other manufacturers decided to cut costs and go for electronic inputs.
As for the TL071.........No...... That one isn't in my vine and yet it's everywhere. No harm in Vu Meters that' about it's home place.
rich
Making a bipolar cap weinstro Parts 7 13th May 2009 03:35 PM
Regulated Power Supply. Bipolar, JFET or MOS? Kenneth Zhu Tubes / Valves 4 30th December 2007 09:30 AM
Can I replace BF245C JFET with J201 JFET? bigmike216 Parts 2 7th December 2005 07:50 AM
Jfet/bipolar PCB and Schematic (finaly) sonnya Solid State 35 31st October 2003 03:39 PM
How does this bipolar look? punchpeanut Solid State 11 2nd October 2003 08:48 AM
Page generated in 0.17440 seconds (84.27% PHP - 15.73% MySQL) with 11 queries
