#61 | ||
Not for being a pain. Still before you can compare the opamps, there optimum working conditions, as described by the designer have to be meet. It could be bypassing caps, as already mentioned source impedance. (Jfet are subjected to higher distortion when the imbalance of the source impedance is not corrected). Notes on how to add a series resistor to the Cf like the one in the AD797 datasheet ... The addition of RS has actually great impact on the open-loop gain and phase margin as shown in the datasheet figure 14. Then you have to have very high CMRR on your measurement tools, not to get the result distorted by a low CMRR. When all this is okay, then you can start comparing. Even though you still needs to take PRR's words into account. Quote:
The pain. |
#62 | ||
that thing about optimizing topology sounds very nice on theory, but how can you be sure you are comparing the opamps only or you are comparing different topologies? where to set the line? this test wasn’t made to measure the lower distortion I could achieve but compare different devices on a typical application! A Pre-Amplifier Quote:
instead saying my test is wrong, please do the test yourself and refute my findings! it would create a very nice discuss Cheers
NE5534 Rules! |
#63 | |
I'm not even buying into this thread.... it's an entertaining read though Terry |
#64 |
Banned
Most be losing my touch. Didn't think that I was getting that soft in my old age.
Oh well.......... Jocko |
#65 | |
See section titled "Cascode to the Rescue" on page 30 here: http://www.tkhifi.com/div/Erno_Borbe..._articel_1.pdf Borbely uses discrete circuitry; however, it seems that cascoding ought to help integrated devices as well. JF |
#66 |
Douglas Self has a website with THD graphs of the NE5532 and the OPA627 (and other BJT and FET opamps).
See: http://www.dself.dsl.pipex.com/ampins/webbop/opamp.htm JF |
#67 | |
Cheers, Terry |
#68 | ||
degenerated for same gain, Jfets are more linear than BJT's but not by much. I've measured it with AP. However the jfets have much worse capacitance modulation with voltage swing so I assume this is hard to deal with in monolythic low supply voltage (+-15) implementations and at higher frequencies there is less feedback to correct it. Having said this, I feel a good newer opamp such as OPA627 is quite superior sonically than the 5534 in most low gain applications. I (and client) have compared 5534 vs 627 in mixing desk summing point and the 5534 became much more sonically constricted when more channels+level were introduced. The 627 was cleaner and stayed cleaner longer with bigger levels and more channels. No question. We have compared 5534 vs 627 in DAC I-V, as stated before the 5534 is a bit slow for this application, the 627 was way better. Quote:
As a related point you appear to be a pro audio guy, I know early series SSL's were riddled with 5534's and these consoles are known for thier bad sound (but incredible flexibility) They have since introduced the J series which was much better and now the K series. Are these still full of 5534's? Terry |
#69 | ||||
Remembers me one talk I had with a friend that is the Meyer Sound loudspeakers importer for Portugal, they had one model that had one type of compression driver that generated a lot of distortion because of the used topology of the horn, but people seamed to like very much that speaker wen they first listened to it, because of it's rich highs As you can see the ear can be easily tricked... Quote:
Here in Portugal we have a pretty small music market and it isn’t easy to rentable such an expensive console. Quote:
Cheers Ricardo
NE5534 Rules! |
#70 |
Wow, what a thread...
I find the 5532's sound inoffensive and honest, for lack of a better word... It reminds me a bit of a 4556. Anyway, I always find myself going back to the sound of a BJT over a JFET. If I listen to two circuits, each carefully designed and built to accomodate either transistor, I find the JFET one has something that slowly wears on my nerves. It is an artificial sound, mostly concentrated in the upper presence band. The BJT sounds more neutral in comparison, and often times seems to sound more open and spacious. Though not exactly on topic, I find MOSFETS configured as a gain device can often have a sweet sound, almost triode like. They are sensitive to circuit design however... I have listened to some MOSFET amps that sound "misty" and thin. I wish MOSFETs were not so static sensitive, and that they had a better reliability record--they are not forgiving devices, certainly nothing like a BJT.
Oh frack!! |
| Making a bipolar cap | weinstro | Parts | 7 | 13th May 2009 03:35 PM |
| Regulated Power Supply. Bipolar, JFET or MOS? | Kenneth Zhu | Tubes / Valves | 4 | 30th December 2007 09:30 AM |
| Can I replace BF245C JFET with J201 JFET? | bigmike216 | Parts | 2 | 7th December 2005 07:50 AM |
| Jfet/bipolar PCB and Schematic (finaly) | sonnya | Solid State | 35 | 31st October 2003 03:39 PM |
| How does this bipolar look? | punchpeanut | Solid State | 11 | 2nd October 2003 08:48 AM |
| Page generated in 0.14610 seconds (85.69% PHP - 14.31% MySQL) with 11 queries |
