Old 25th November 2003, 03:36 AM   #41
Send a message via AIM to jewilson
Default Ricado these numbers what are they suppose to mean
Ricardo,
What do these numbers mean? What type of test did you run, what was the point of the test and what does it prove. In addition, let us in on you test configurations so we can be enlighten.
Jim W.
Old 25th November 2003, 03:54 AM   #42
Account Disabled
Default Re: Well many of us then perfer them in some way......
Originally posted by jewilson
Well If there were only 709's, 741, uA739, 540's, available in this world then I might think that a 5534 was some kind of marvel. Having said that, na I would use tubes.
I used to use 324s and thought they were great, until I used the TL0xxs. Well, the 324s aren't bad with a light load. But under heavy load (I were bootstraping them in a power amp), they didn't do too well.
Tim, sorry you can here the difference, but where did you do this research. You must have been in bad environment maybe faulty towers.
it must have been the power cords,
Old 25th November 2003, 04:12 AM   #43
dimitri is offline dimitri  United States
dimitri's Avatar
Send a message via ICQ to dimitri
John, I have a hardcopy, but sorry it is on the other side of the Earth. I can send it to you not earlier than a New Year. If you are in a hurry you could order through AES for $5:
http://www.aes.org/publications/preprints/search.html
Alternately, you can download Wurcer US patent 5,166,637
http://patft.uspto.gov/netacgi/nph-P...r&RS=IN/Wurcer
Old 25th November 2003, 04:28 AM   #44
johnferrier's Avatar
The other sources you provided are fine. Thanks!
JF
Old 25th November 2003, 09:12 AM   #45
Electrons are yellow and more is better!
peranders's Avatar
Originally posted by rickpt
the null test results
What is the file type? I don't get any .??? at the end.
/Per-Anders (my first name) or P-A as my friends call me
Old 25th November 2003, 12:44 PM   #46
Ricardo,
Thankyou for the op-amp null test figures....interesting!
Tim.
Old 25th November 2003, 01:39 PM   #47
rickpt is offline rickpt  Portugal
rickpt's Avatar
setup: non-inverting amplifier with a(I chose this gains figure to use the OPA637 and the resistors were handy at that time) gain of five times and a 50k pot at the front end.a typical single opamp Pre-Amplifier
distortion could be a little lower if I used lower gain settings... as the setup was equal to all opamps,this cannot be blamed
about the null test like I said before, there is a lot of input about this test made by my friend Tube Dude in this forum, just search...
in short terms, it's a differential test that directly compares the input with the output leaving only the thing that cant be nulled, all nonlinearities created by the amplifying stage! lower the value, more the output resembles the input! one thing great about the test is that the distortion of the generator isn’t a problem like the typical distortion tests and that severely limits resolution of those tests
about the file, it's a word file
cheers
Ricardo
NE5534 Rules!
Old 25th November 2003, 02:14 PM   #48
sonnya is offline sonnya  Denmark
sonnya's Avatar
First of all.. It can be blamed.
Design you circuit to match the opamps you are using.
1. A good example is the OP275GS/GP from analog. On page 9 in the datasheet there is a section called "Attention to source impedance Minimizes distortion"
There is descriped how a source impedance of more than 2Kohm and unballanced will affect its distortion performance alot.
That is because of capacitance modulation.
2. The AD797 outperforms the NE5534. There was an article in EW about capacitance distortion. The author have made a very pure sine wave oscillator. The distortion dropped below the NE5534 when he added a series resistor of 100R to the Cf. Reason .. Because of the very low rbb of the input diff. pair it needed a series resistor to dampen the capacitive interactions.
Look at page 10 in the datasheet.
So when it all sums up. The tests have to take there working conditions into account before comparing the specs and sound quality.
Sonny
Old 25th November 2003, 03:15 PM   #49
rickpt's Avatar
whit a 50k pot that gives you about 10k of output inpedance at mid point position, fet amplifiers should be at home, and bipolar amplifiers should perform much worse... that wasn’t the case!
did you verify this with a null test? remember that the null test isn’t a typical thd test! all non linearity’s are measured.
about that resistor I don’t believe that was the case... I believe that Mr. Bateman had a parasitic oscillation when he inserted the AD797 on the circuit, and that resistor dampened that oscillation, and off course, distortion was lower, so nothing more than a base stopper...
now look at the typical diy'er, normally the topology is the same and only opamps are swapped...that was what I did but instead of listening, I was measuring
it's fairly easy to do a null test , so do it yourself and find your results...
cheers
Ricardo
NE5534 Rules!
Old 25th November 2003, 03:50 PM   #50
It's a zip file with a MS-Word doc inside. I just redownloaded, it works fine here.
JF
Making a bipolar cap weinstro Parts 7 13th May 2009 03:35 PM
Regulated Power Supply. Bipolar, JFET or MOS? Kenneth Zhu Tubes / Valves 4 30th December 2007 09:30 AM
Can I replace BF245C JFET with J201 JFET? bigmike216 Parts 2 7th December 2005 07:50 AM
Jfet/bipolar PCB and Schematic (finaly) sonnya Solid State 35 31st October 2003 03:39 PM
How does this bipolar look? punchpeanut Solid State 11 2nd October 2003 08:48 AM
Page generated in 0.14036 seconds (81.49% PHP - 18.51% MySQL) with 11 queries
