#21 |
I have to support jewilson
. NE5532 measures well, but fails when influenced by D/A spikes from CD and RF interference, cannot manage it. He is right, every BB like 2134 etc. is better. And - 5532 has horribly high input bias current and current noise. So called advantage of low voltage noise can be utilized only for source output impedances and input resistors of some 100 Ohms.
#22 |
Banned
Some of the stuff in this thread is ludicrous. But what do I know........30+ years of doing this has taught me nothing.
Jocko |
#23 |
Nope, I've just checked and the original question wasn't "is the NE5532/4 any good?".
Op-amps make sense in low cost and pro equipment where there are constraints on cost, power consumption, board space, heat dissipation and where an impressive on-paper specification is important. But for us DIYers, at least as far as pre-amps are concerned none of the above is really an issue. Connecting up an op-amp can hardly be described as 'designing a high-end pre-amp'. |
#24 | |
Electrons are yellow and more is better!
Maybe you can take some advice from Jocko if he want to give any. He knows something I believe.
/Per-Anders (my first name) or P-A as my friends call me |
#25 | |
My AD8610/BUF634 headphone amp is not boring. ![]() Can be seen here
#26 |
OP27, OP37, OPA2604, OP249, OP275, LM6172/ AD825/26, AD797 AD8610, OPA627, OPA637, OP134, AD8610, AD8620. These are just a few of the part that sound better than the yesterday news 5532/4 parts.
An for most applications the FET sound better low odd harmonics. I mean you don't see any bipolars on the front end of any of Nelson's, Curl work now why is that.
Jim W. |
#27 |
I am reminded of the story of the ''audiophile'' who returned home from a concert complaining that there was not enough ''presence''. The quest for clarity, detail and precision is fine up to a point, but every recording represents an imperfect replica of a real musical event and posesses imperfections that easily distract the listener from the music. As a musician I know how music sounds both on and off stage, the most cohesive sound is often to be found some way from the stage.
In my view FETs produce an unnatural spotlight on detail, rather like sitting in the front row. I find Bipolar devices convey a more balanced sound, not quite as detailed as the FET sound, though more realistic overall. In general I have found BJTs convey a more realistic sense of perspective. This brings us back to the NE5534 which incidentally is a dual version of the NE5533 according to the datasheet, not the NE5532. I don't pretend it is perfect, my discrete S.E. class A op-amp circuit sounds better to me, but the NE5534, especially when biased into class A, plays music with sufficient clarity, tonal neutrality and a believable perspective in a way that I have not experienced with many more modern IC op-amps. Regarding the previously suggested (in this thread) visit to the doctor for a cure for the NE5534 ''thing'', doctors are very well educated people who enjoy good music and culture, the NE5534 might be to their liking! Tim. |
#28 | |
#29 |
Well If there were only 709's, 741, uA739, 540's, available in this world then I might think that a 5534 was some kind of marvel. Having said that, na I would use tubes.
Tim, sorry you can here the difference, but where did you do this research. You must have been in bad environment maybe faulty towers.
Jim W. |
#30 |
Banned
You forgot TL0x1s,and the like. And LM833s too, although some here seem to think that they are also good.
If they are so good, then why didn't the place that buys my pull-outs want them?? Answer: they couldn't sell them. About the only truly useless crap that I have pulled out in the last 20 years. Jocko |
| Making a bipolar cap | weinstro | Parts | 7 | 13th May 2009 03:35 PM |
| Regulated Power Supply. Bipolar, JFET or MOS? | Kenneth Zhu | Tubes / Valves | 4 | 30th December 2007 09:30 AM |
| Can I replace BF245C JFET with J201 JFET? | bigmike216 | Parts | 2 | 7th December 2005 07:50 AM |
| Jfet/bipolar PCB and Schematic (finaly) | sonnya | Solid State | 35 | 31st October 2003 03:39 PM |
| How does this bipolar look? | punchpeanut | Solid State | 11 | 2nd October 2003 08:48 AM |
| Page generated in 0.21536 seconds (47.60% PHP - 52.40% MySQL) with 11 queries |
