Old 15th February 2013, 11:53 PM   #1
Default Advice with tuning up old school car Sony Amplifier signal path.
I have a XM-460GTX 4 channel car audio mosfet output amp that I found on ebay and would like advice on the input stage for the high drive input... it currently has .22uf input caps with the rest of the signal path showing 4.7uf or bigger. I am wondering if I can bypass these or use a higher value?
Also -- suggestions for IC upgrades?
See the preamp schematic attached.
Thanks,
MFA
Old 16th February 2013, 03:44 AM   #2
jerluwoo's Avatar
There is no advantage to be had replacing those caps with a larger value. As for replacing the opamps Op-amp Replacement for 4580 (JRC)
Old 16th February 2013, 09:01 AM   #3
Wouldnt worry much about the high level input .. No point as the distortion from whatever is driving it will be quite high
Sony XM-120 (Very old school) for the new school Dr Zeus Car Audio 8 8th June 2013 06:54 AM
Hybrid Circlotron Amplifier with only 3 components on the signal path audiodesign Tubes / Valves 199 11th February 2013 08:26 AM
Polypropylene for signal path rg12 Parts 10 26th August 2010 09:38 PM
value of capacitors in signal path Oystein Analog Line Level 24 11th February 2010 07:43 AM
Help identifying the signal path Eric Solid State 7 24th August 2001 08:10 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
