Single Ended Solid state preamp - Page 5 - diyAudio
Old 11th May 2013, 03:49 PM   #41
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
Originally Posted by Mooly View Post
If you download the program this .asc file of your preamp (unzip the folder) will run straight off.
You can see the amp is inverting. The response extends to many Mhz. Bottom end is poor due to the 0.047uf cap.
I forgot to add the decoupling cap after the 1K resistor which will slightly alter the AC characteristics... but I'll leave that for you to add
If you get stuck then ask.
Thanks for simulating
I'm an old type pencil and paper Engineer (started Engineering in 1969 ) and "old dog learns no new tricks" but it's nice to see that simulation confirm classic design performance.
Just one small detail, "0.047uF" was a typo, corrected in the following answer to:
Sorry, I intended to write 0.47uF, which would have a cutoff frequency below 10 Hz.
1uF is fine, of course.
so if you want to re-simulate with 0.47uF , fine.
Maybe this old dog should practice some Spice, after all.
As a side note, original Spice was available way back then ... but we run it in an IBM1620 computer
No monitor, of course
Curves/answers were drawings made out of asterisks " * " on a blanket size sheet of paper *or* long lists of numbers.
Not exactly user friendly
So it was ***much*** faster to simply use one of these:
Thanks again
EDIT: did we have a *mouse* way back then?
Of course!!, what did you think?
We called it "Mickey", it used to live behind a bookcase and we fed it cookies
Old 11th May 2013, 05:22 PM   #42
Mooly's Avatar
Here you go with a 0.47uf cap. Around 13Hz for the -3DB point.
Second shot is with a 2N3055 Nice gentle roll off outside the audio band... who need filters
Old 11th May 2013, 06:10 PM   #43
JMFahey's Avatar
Thanks again.
Even with 2N3055 , "flat within the audio band".
Old 11th May 2013, 07:19 PM   #44
Mosquito's Avatar
wow! !!! :-)
"It is less serious than if worst"
Old 11th May 2013, 09:39 PM   #45
JMFahey's Avatar
Hi Mosquito, thanks for simulating, but you used a 1K load, too low for this simple preamp.
It expects around 10K or higher.
It still works, of course, but you lose gain and PP excursion with it.
PD: Santa Fe? Dónde?
Un abrazo.
Old 11th May 2013, 10:02 PM   #46
Mosquito's Avatar
Hi, yes , just wanted to see what if... an extreme worst case load.
Santa Fe ciudad, humidity, low atmospheric pressure, and .. mosquitoes!
Old 13th May 2013, 01:40 PM   #47
Jempie is offline Jempie  Indonesia
hi i see the output is inverted, must is change this.
or just play inverted or change the + to - and - to + on the output
Old 13th May 2013, 02:05 PM   #48
Mooly's Avatar
You can't really swap the outputs because of the grounds. An inverting amp (and many are) isn't a problem although some claim to be able to sense absolute phase.
Try an experiment. Listen to some music and then reverse both speaker lead polaritys and listen again. Can you tell any difference ?
Old 13th May 2013, 02:59 PM   #49
Mooly, correct me if i'm wrong does the signal is inverted?
If i messure + = - is this normal in the design?
Thx
Old 13th May 2013, 04:24 PM   #50
Mooly's Avatar
All it means is that as the input voltage rises, the output voltage falls and vice versa. Forget signals and AC. Think about it at DC. The base of the transistor is biased to some set voltage by the resistor network. If the voltage at the base is "altered" the collector voltage alters too. Base voltage goes up, the transistor conducts more, the collector volts fall. Base volts fall, the transistor conducts less, the collector voltage rises.
Class A solid state single ended spiritm2r Pass Labs 2 24th February 2010 09:23 PM
URL collection of Single Ended Solid State Output Stages tiefbassuebertr Solid State 0 27th June 2009 06:53 AM
Single ended solid state amplifiers? fotios Pass Labs 8 11th August 2008 07:29 PM
17 W Single Ended Solid State Power Lars Clausen Solid State 7 27th October 2003 08:46 PM
Copyright ©1999-2017 diyAudio
