Single Ended Solid state preamp - Page 4 - diyAudio
Old 10th May 2013, 12:26 PM   #31
Jempie is offline Jempie  Indonesia
Fahey
this one
Originally Posted by JMFahey View Post
Try this:
Gain: 10X
Zin: around 40K
Z out: 4K7
Transistor: BC546B or C
Or any general purpose low signal NPN, Hfe around 300.
Fed from 20 to 30 V single rail.
This is what's normally achievable from a single transistor without stretching the envelope.
i use a a source an cd-player and stereo amp msd A200s as loudspeakers regulair 2 way system one 89 db.
Old 10th May 2013, 03:47 PM   #32
JMFahey is online now JMFahey  Argentina
JMFahey's Avatar
How does the CD player sound connected straight to the amplifier?
When using the preamp, do you use some volume control?
Old 10th May 2013, 05:32 PM   #33
the volume control 20K dact from cd player to dact from dact to input preamp
Old 10th May 2013, 07:26 PM   #34
JMFahey's Avatar
Well, maybe you are losing highs in that dact to dact connection with a pot in the middle.
The preamp by itself is flat.
Maybe somebody simulates it and posts a frequency response curve.
Old 11th May 2013, 10:08 AM   #35
Is there free software where i can simulate this preamp just to check what happen
Old 11th May 2013, 10:58 AM   #36
a friend of mine make this to try
Old 11th May 2013, 11:27 AM   #37
Mooly's Avatar
LTspice IV
Linear Technology - Design Simulation and Device Models
Old 11th May 2013, 11:58 AM   #38
Mooly's Avatar
If you download the program this .asc file of your preamp (unzip the folder) will run straight off.
You can see the amp is inverting. The response extends to many Mhz. Bottom end is poor due to the 0.047uf cap.
I forgot to add the decoupling cap after the 1K resistor which will slightly alter the AC characteristics... but I'll leave that for you to add
If you get stuck then ask.
File Type: zip Simple Preamp.zip (710 Bytes, 23 views)
Old 11th May 2013, 12:13 PM   #39
Mooly,
Thanks for that great help, how can I simulate the schematic of my friend or is this the same
can i edit myselve? is there a way to add other transistors like to see waht happen when i use the KT603
many thanks
Old 11th May 2013, 01:11 PM   #40
Mooly's Avatar
Download and install Spice and download and unzip my file and save it somewhere such as documents.
LTSpice is a long learning curve but I would recommend 100% Bob Cordells book "Designing Audio Power Amplifiers" which has whole sections on using LTSpice for complete beginners. It all makes sense
To get you started...
Open (run) LTSpice and click "file" at the top left and "open" and browse for the .asc file you have saved. Click it and the file will open.
Right click the circuit and select "edit simulation CMD" Among the options are "DC op pnt" Select that and the DC conditions of the circuit can be probed. Select "AC Analysis" to plot the response of the circuit. You set the limits and scale. Transisent allows you to probe the circuit as if you were using a scope. You have to put a stop time in such as 10ms.
You can use different models (but thats a more advanced option) but for your circuit it won't make any difference in either simulation or reality what devices you use as long as they are generally suitable NPN small signal type.
The book I mentioned will take you from zero to more thn pretty competent in easy steps. And Bob has all the circuits on his website as downloadable files.
Class A solid state single ended spiritm2r Pass Labs 2 24th February 2010 09:23 PM
URL collection of Single Ended Solid State Output Stages tiefbassuebertr Solid State 0 27th June 2009 06:53 AM
Single ended solid state amplifiers? fotios Pass Labs 8 11th August 2008 07:29 PM
17 W Single Ended Solid State Power Lars Clausen Solid State 7 27th October 2003 08:46 PM
Copyright 1999-2017 diyAudio
