diyAudio (
-   Solid State (
-   -   Project for christmas... (
Paprika 20th November 2003 07:26 PM
Putting the exact project details in the background until I finalize my plans. What I wanted to know is if there is a way I can integrate an equalizer into an amp I am building. If so how would I go about doing that?
You see, my ideal is a chip 2.1 channel amp that has a source selector on-board which would let me hook up like 4 different audio sources and switch between them as I wish by the push of a button. That I am not too worried about right now, what I need to know is if it is possible to build an on-board equalizer, how hard would it be? And would it manipulate the unamplified signal then run it into the AMP or get the amplified signal and manipulate it?
Solid Snake 20th November 2003 08:18 PM
You're probably not going to find a chip with a source selector. You can build one out of a TTL counter, demultiplexer and mini relays. Your EQ goes before the amp.
Paprika 20th November 2003 08:35 PM
Yeah I know I won't find a chip with source selector, I plan to build that myself. I just was wondering how I'd go about making an EQ..
Solid Snake 21st November 2003 04:13 PM
How many bands are you planning on the EQ?
Paprika 21st November 2003 07:50 PM
Ha! I dunno... Maybe 10...
Right now I am still researching, I may not need an EQ after all but I wanted good sound which I could adjust
Resources saved on this page: MySQL 18.75%
