nikko na-590
nikko na-590
Old 13th February 2013, 04:22 PM   #1
adason is offline adason  United States
adason's Avatar
Default nikko na-590
hi, can anyone help with schematics? it would be much appreciated, I need to make some repairs
Old 26th February 2013, 05:32 PM   #2
adason's Avatar
anyone?
no one?
Old 26th February 2013, 05:59 PM   #3
Tekko is offline Tekko
Banned
Have you tried emailing this guy about the service manual ?
NIKKO Manuals available
Old 26th February 2013, 06:51 PM   #4
adason's Avatar
thanks for info, I will contact him
Old 26th February 2013, 10:57 PM   #5
Smiley 09 is offline Smiley 09  Europe
Smiley 09's Avatar
Originally Posted by adason View Post
anyone?
no one?
''NIKKO NA590 Service manual''
Maybe You should try HERE and be LUCKILY redirected to a DL server.
I was try to DL the file a few times but after the DL starts
it is interrupted for no reason at some 70-90% of the file downloaded .
Maybe You'll be more lucky with DL.
Old 26th February 2013, 11:52 PM   #6
adason's Avatar
Smiley, I did not have luck either, but thanks anyway.
Old 27th February 2013, 08:44 AM   #7
Smiley 09's Avatar
-NIKKO NA2000 SM-
Maybe You should try THIS ONE which is availl.at the bott. of the page , perhaps this one is minimal features diff. but mostly the main SCH
design is theirs constant . . . ?
Maybe You'll be able to source the problem and solve it . .
Old 27th February 2013, 09:42 AM   #8
east electronics is offline east electronics  Greece
east electronics's Avatar
550 and 590 are available from me free of charge as usual these should be close,
state the nature of your trouble i might be able to help
also post pictures of your amp or email me to get the schematics
kind regards
sakis
SERVICE ΕΝΙΣΧΥΤΩΝ ΚΑΙ ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 27th February 2013, 12:10 PM   #9
adason's Avatar
hi sakis, thanks, I appreciate it, i will pm you
i emailed Norman from web Tekko suggested, but got no response yet, but it was just yesterday
i do have many service manuals from hifiengine
Nikko | Owners Manuals, Service Manuals, Schematics, Free Download | HiFi Engine
whatever similar models, just to have an idea of schematics
so here is a deal with NIKKO, few weeks back I got nikko beta 20 preamp and nikko na-590 integrated amp chieply of ebay, just for fun
there is a thread about beta 20 preamp, its a rather good preamp, mine has some phono section switch issue I need to address and I have already recaped the whole unit, it sounds great especially phono section, but lets not talk about preamp
NA-590 integrated amp came to me with three broken of pots on the front, not just shaft broken off, but shattered pots for bass treble and balance. I put resitors there for now and was able to test the unit. Basically the amp works, but was probably not used for a while, so it needs to be recaped definitely. It sounded bad from first, but it got better, and now its rather good sounding. I need schematics, in order to know what caps are in signal pass and I would like to bypass the tone control section completely, since I have that beta 20 preamp.
Now looking inside, this integrated amp is probably rather basic, very few parts here and there, even worse, I do not see output reley! There are most likely no caps on the amps output, since I see none on the board, and assuming its DC, its rater dangerous. For such an old amp if it fails, it may take speakers with it. I see no DC sensing circuitry. Thast why I would appreciate schematics, I'd like to make it safe, add delay and DC sensing circuitry. Besides, now it makes loud turn on thump, and when you turn it of, music plays till the power suply caps last! Rather primitive...
Phono section of NA-590 looks terrible, I did not even used it...so I want to make NA-590 just a power amp and use it with beta 20 pream in the guest room, or in basement for speaker testing/building.
I believe these vinatage components deserve second life.
Thanks everyone for help.
I will post as many pictures as you like.
Old 27th February 2013, 12:39 PM   #10
well ..here is what i think
at first look an amplifier that generic might be bad practice to use for such an application again no protection for a ""testing "" amplifier is a very bad thing to do ...Shape him up if you like but use it for the correct purpus such a very secondary system with casual duty and with in expensive speakers .
if you are willing to go on in such a generic amplifier as said a complete recaping is a must and caution will be needed if the amplifier is bootstrap you dont mess up with that value and same goes for feedback capacitor ...all the rest can be seen with a naked eye ...
Post a picture of the board i will let you know a couple of things ...
as about the thump can be caused by dry electrolytics and may self curred after replacing capacitors and aditionally adding bleed resistors to quick ensure that the cans emty pretty fast
i remember the switch/preamp issue and if i rmember well i sugested replacing the switch with audio grade relay and a piece of wire and you are done ...should be a walk in the park to do ...
kind regards
sakis
PS been checking the schematics i have and sadly none of them is even close to your amp ..wrong from my side as a suggestion
nikko na-590Hide this!Advertise here!
Yamaha CDX-590 laser adjustments? HWTest Digital Source 3 20th December 2012 07:57 PM
Nikko na-850 trd1587 Solid State 7 20th February 2010 06:07 PM
WTB: Senns 580 590 600 aggrojosh Swap Meet 2 31st August 2003 11:33 PM
sony CDP-590 Service Manual..anyone? tone Digital Source 2 5th January 2003 05:02 PM
mods for Yamaha CDX-590 Mr. Triatic Digital Source 0 2nd March 2002 07:39 PM
