Common mode filter choke...
Old 20th November 2003, 05:41 PM   #1
JojoD818 is offline JojoD818  Philippines
JojoD818's Avatar
Default Common mode filter choke...
While I was cleaning my room I found this coil looking thing and so I surf the net and found out it was called a common mode choke. I have a bunch of this lying around, what are they for? Can I use them for filtering my supply rails? Are they for AC or DC? What should I do with them?
JojoD
Old 20th November 2003, 09:17 PM   #2
djmiddelkoop is offline djmiddelkoop  Netherlands
djmiddelkoop's Avatar
JoJoD,
those are very good for blocking common noise (i.e. noise which is present on both wires).
You can use them in your mains AC line input, or if they are beefy enough at the secondary of your transformer before the rectifier.
Make shure the coil doesn't get saturated by to much current going through, as it won't work anymore. Because of this it is not recommanded to use it with DC current.
Dick.
“Information is not knowledge Knowledge is not wisdom
Wisdom is not truth Truth is not beauty Beauty is not love Love is not music Music is THE BEST”
Old 21st November 2003, 01:54 AM   #3
JojoD818's Avatar
djmiddelkoop,
Thanks for the idea. So I can use it for AC mains conditioninig. They look like this...
Old 21st November 2003, 04:58 PM   #4
Yes,
they are perfect for that and that's the way they look like.
Dick.
Old 22nd November 2003, 12:13 AM   #5
JojoD818's Avatar
I also have a bunch of those small toroidal looking chokes that came from pc psu. I was hoping I can re-wound it and make use of it in filtering mains or my rails just before the bridge rectifier.
JojoD
Old 22nd November 2003, 12:23 AM   #6
li_gangyi is offline li_gangyi  Singapore
li_gangyi's Avatar
they can make nice effieient switching inductors for a small SMPSU....been doing that for a long time...
Kids in the back seat cause accidents...Accidents in the back seat cause kids...
Old 22nd November 2003, 06:29 PM   #7
JoJod,
no don't rewind these chokes but use them in your AC line filter as well !
For instance, put then in series with each half of the commonmode choke or after your rectifier diodes for noise surpressing.
As you may understand these chokes work only with high frequencies usually those out of the audio bandwith.
Dick.
Old 22nd November 2003, 09:58 PM   #8
JojoD818's Avatar
Alright! I knew it all along, these things still has some use.
Thank you...
JojoD
Old 23rd November 2003, 12:30 PM   #9
li_gangyi's Avatar
they've got a lot of uses...filtering line noise...such things...might find a few outta monitors and such
Old 23rd November 2003, 01:56 PM   #10
JojoD818's Avatar
I just asked a friend who has a pc repair shop to give me his junk pc psu... the chassis is good for test psu, the caps inside are also good for filtering and then, there are lots of those toroid looking filters!
If you guys have some sample implementation for such.
JojoD
Common mode filter choke...Hide this!Advertise here!
Common-mode choke discussion please stellavox Power Supplies 8 25th July 2009 12:00 AM
Common mode choke model eyalne Tubes / Valves 4 25th February 2008 10:22 AM
common mode choke question schiller Tubes / Valves 4 13th February 2008 09:34 AM
isolation transformer as common mode choke? av-trouvaille Power Supplies 3 4th July 2005 10:33 AM
Initial experiences with a common mode choke Dr.H Tubes / Valves 7 7th August 2002 08:59 AM
