Common mode filter choke...
Old 27th November 2003, 07:37 AM   #11
ashwin is offline ashwin  India
Exclamation carefull!
Originally posted by JojoD818
I also have a bunch of those small toroidal looking chokes that came from pc psu. I was hoping I can re-wound it and make use of it in filtering mains or my rails just before the bridge rectifier.
JojoD
JojoD,
you must ensure that those chokes are really meant for common mode filtering Check the winding directions on both coils on that torroid. If they are not wound for common mode use, then the flux in the ferrite core would cause huge currents to flow in the core, heating it up and cracking it. The heat could burn the insulation off the windings as well, and cause a mains short. I know because this is exactly what happened to me! I wound the coils for a common mode choke the wrong way and had some nice fireworks
As I understand it, a common mode choke must have negligible flux in the core during normal operation (i.e. the fluxes from the two windings must cancel each other). Only in the presence of common mode noise is some net flux generated in the core. What this means essentially is that the choke acts as a short for differential mode AC, and a high inductance for common mode AC line noise, thus allowing it to pass the normal (diff-mode) AC and block the common mode noise.
- Ashwin
Old 27th November 2003, 02:59 PM   #12
JojoD818 is offline JojoD818  Philippines
JojoD818's Avatar
ashwin,
thanks for the insight. I myself am very careful especially when tinkering with mains wiring.
JojoD
Common mode filter choke...Hide this!Advertise here!
Common-mode choke discussion please stellavox Power Supplies 8 25th July 2009 01:00 AM
Common mode choke model eyalne Tubes / Valves 4 25th February 2008 11:22 AM
common mode choke question schiller Tubes / Valves 4 13th February 2008 10:34 AM
isolation transformer as common mode choke? av-trouvaille Power Supplies 3 4th July 2005 11:33 AM
Initial experiences with a common mode choke Dr.H Tubes / Valves 7 7th August 2002 09:59 AM
