Replacing 100KAX2 with 100KBX2 - Page 2 - diyAudio
Old 14th February 2013, 03:37 AM   #11
Hi all, Thanks for the advice. I'm glad that I'm a member of this forum !
Here is the one I have bought recently as a replacement:
1pc Potentiometer 100K Log Alps Audio Amp Volume Control Pot Stereo w Loudness | eBay
(fyi : The original pot in the amplifier also had center taps)
Old 14th February 2013, 10:22 AM   #12
Hope it is okay to use the new pot in the amp?
Old 15th February 2013, 03:21 AM   #13
Hi all,
Is this pot fine?
Thank you.
Old 28th May 2015, 03:56 PM   #14
I have a stereo amplifier which had the same problem with the volume potentiometer. It has also the same reference 100KBX2, also four connections and has even another feature that I like very much: in the back of the double potentiometer and also connected to the spindle, it has a gear which has its teeth engaged in a sphere pressed against them making the "clic-clic-clic" feeling when one turns the potentiometer. The potentiometer was not working properly as in most off the travel there was no sound; sometimes the sound came but was in positions where the volume was too loud. Therefore, was impossible to select a proper volume.
Following the suggestion in the beginning of this thread, I applied on the inside of it (from two openings that it have in its case) a little of contact cleaner (Philips contact cleaner 390CCS), turned several times the spindle to the left and then to the right and allow some time to dry. After that, I tried the amplifier and the potentiometer was now working properly!!!
Old 29th May 2015, 08:52 PM   #15
east electronics's Avatar
No matter what the schematic or the type of pot is stated in a volume application there has to be a log pot
Checked with the schematic of your amp and there is NO linear pot together with resistors to make it log .So the original pot was LOG one way or another
Proceed !!
SERVICE ΕΝΙΣΧΥΤΩΝ ΚΑΙ ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
ALPS RK168 50KAX2 100KAX2 tommy54 Vendor's Bazaar 136 26th February 2017 07:02 PM
ALPS 100KAx2 with moto uhcmos Swap Meet 10 21st September 2010 12:06 PM
Copyright 1999-2017 diyAudio
