How to control 6 inputs with 1 pot???
Old 20th November 2003, 04:11 PM   #1
JojoD818 is offline JojoD818  Philippines
JojoD818's Avatar
Default How to control 6 inputs with 1 pot???
Hi everyone,
I have a DVD player that has 6 outputs...
1. Front Left
2. Front Right
3. Center
4. Surround Left
5. Surround Left
6. Surround Center
Now the question is, if I will build a 6 channel amp, how do I control the volume? What I want is to control the volume of the 6 channels with one control. Is it possible?
JojoD
Old 20th November 2003, 05:13 PM   #2
richie00boy is offline richie00boy  United Kingdom
Did it Himself
richie00boy's Avatar
Use VCAs (Voltage Controlled Amplifiers) or digital potentiometer/volume control chips, slaved off one pot/volume control.
Old 20th November 2003, 05:37 PM   #3
JojoD818's Avatar
Can you and others please point me to a circuit that uses vca for volumes. I also like the digital volume control but I don't know anything about digital electronics.
JojoD
Old 20th November 2003, 06:07 PM   #4
Da5id4Vz is offline Da5id4Vz  United States
Da5id4Vz's Avatar
Send a message via AIM to Da5id4Vz
This is an interesting thread related to your question:
http://www.diyaudio.com/forums/showt...threadid=22768
While this thread deals w/ a 2 channel implementation, others have done similar builds out to six channels.
The elusive APOX web site can be found here:
http://www.apoxcontrols.com/apox.htm
and the new site looks darned good too.
Old 20th November 2003, 06:20 PM   #5
Vinnie R. is offline Vinnie R.  United States
Take a look at
http://www.dact.com/html/attenuators.html
They have a stepped attenuator that can control 6-channels at
once.
Another option is the APOX kit, as mentioned above. You may or may not want the added complexity, but it does sound great and is an awesome kit!
Old 20th November 2003, 07:29 PM   #6
till is offline till
Banned
very cheap and simple, without all the display, balance, etc. options the apox kit has as advantage, i made this. Should be easy to use for 6 channels. http://home.tu-clausthal.de/~tpa/PGA/index.html
Old 20th November 2003, 10:15 PM   #7
moamps is offline moamps  Croatia
maybe TDA1524
Old 21st November 2003, 08:23 AM   #8
Did it Himself
Try this
http://www.thatcorp.com/datashts.shtml
Old 21st November 2003, 04:32 PM   #9
Solid Snake is offline Solid Snake  United States
I also wanted to do something like you are doing. I wanted to use a digital volume control or maybe one of those digital pots but they are not very linear so I drew this up one day when I was bored in class, tell me if it makes sense.
File Type: txt attenuator.txt (559 Bytes, 141 views)
Old 22nd November 2003, 12:00 AM   #10
JojoD818's Avatar
I can't figure out the schematic...
Anyway, as for digital, aside for what you said, I don't like digital because I don't know a thing about it and can't implement such. AYour plan uses transistors, now that I can understand somehow.
Can you please redraw?
Thanks,
JojoD
How to control 6 inputs with 1 pot???Hide this!Advertise here!
FET inputs or bipolar inputs on a power amp? ash_dac Solid State 150 17th October 2006 06:27 AM
Copyright ©1999-2017 diyAudio
