FET compound pair?
FET compound pair?
Old 13th February 2002, 04:22 AM   #11
Damon Hill is offline Damon Hill  United States
Location: Auburn, WA (somewhere between Seattle and Tacoma)
Send a message via ICQ to Damon Hill
IGBT
Insulted Gate Bipolar Transistor.
MOSTFET on top of a bipolar transistor; used widely in power
switching circuits, not particularly useful in linear applications,
but it is done. Just doesn't seem to have any advantage over
separate MOSFETs or bipolars in audio amplifiers.
Old 13th February 2002, 02:56 PM   #12
dshortt9 is offline dshortt9  United States
dshortt9's Avatar
What would one call this output configuration:
http://w1.521.telia.com/~u52107110/tr_monster.html
My unproven opinion is that a high bias class AB (1 or 2 amps) may be the solution as the switching transients could be swamped by the current draw of the other phase. Yes/No?
Old 13th February 2002, 03:27 PM   #13
tvi is offline tvi  Australia
tvi's Avatar
<i>"What would one call this output configuration:"</i>
Hiraga Called it an Inverted Darlington I think
James
Old 13th February 2002, 05:40 PM   #14
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
FET compound pair?
In complementary output stages, I was brought up
to call it conjugate complementary. Sziklai I never
heard of.
Old 13th February 2002, 06:18 PM   #15
Geoff is offline Geoff  United Kingdom
James
Your recollection is correct. Hiraga also referred to this output stage configuration as 'Darlingnot'
dshortt9
If you want more than just the schematic for this design, the full original articles are on my website.
Geoff
Old 13th February 2002, 07:27 PM   #16
dshortt9's Avatar
Thanks, Geoff. I've referenced your page before but have not kept up with the updates. Good Work.
Old 13th February 2002, 09:44 PM   #17
sonnya is offline sonnya  Denmark
sonnya's Avatar
Your opinion on CFP mathes norwegian Audio wich maked a DIY class A amplifier some years ago with a BJT CFP and Fet's in the inputstage.. No feedback.
But i think the class A bias was to high... Far higher than the outputstage could handle.... heatsink should be in the area of .2degress/watt per channel.
I think i still have the magazine... I can scan the article tomorow if anyone is interrested?
Sonny
Old 20th March 2003, 07:19 AM   #18
ashok is online now ashok
ashok's Avatar
FET compound pair?
Default Circuit
Hi Sonnya,
Could you please scan the article. Thank you.
I was planning on testing a CFP pair with bipolar input and MOSFET power device and MOSFET input and Bipolar output device. Has anyone compared these in class A or class AB mode ?
Cheers.
AM
FET compound pair?Hide this!Advertise here!
Compound hornloudspeakers angeloitacare Multi-Way 39 11th September 2011 08:06 PM
Compound horns, anyone? brsanko Full Range 30 15th August 2011 02:15 AM
Hartley compound sub rdr Subwoofers 3 2nd October 2006 01:04 AM
sil pad 900s with or without compound? jeapel Pass Labs 3 6th March 2006 07:38 PM
Heatsink compound Thoth Solid State 11 1st January 2002 02:08 AM
