Old 11th February 2013, 04:14 AM   #1
Default Turn on pop on speaker even when using relay
Even when hooking up a relay from the amp output to the relay and delaying the connection for a few seconds, there is a short pop on the speaker after the relay makes the connection. Attached is a pic of the relay part of the amp. How do I eliminate this pop?
Old 11th February 2013, 04:39 AM   #2
When the relay closes, C4 draws charging current through the speaker causing the pop. The solution is to give C4 an alternate charge path. A resistor of a couple of hundred ohms from pin 4 of the relay to ground should do it.
Old 11th February 2013, 05:16 AM   #3
yup that did it, thanks
How to stop turn on pop noise in speaker Fusion916 Solid State 4 5th October 2012 07:08 PM
SAE 2400 turn on/turn off pop Glen B Solid State 16 31st July 2006 01:32 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
