Loop stability clarification . . .
Old 10th February 2013, 02:52 AM   #1
pete_schumacher is offline pete_schumacher  United States
Default Loop stability clarification . . .
Hey guys, I've got a couple Bode plots for you to look at. I'm a bit puzzled by this and hope you can help me sort things out.
First, open loop. Then, closed.
In simulations, the closed loop is stable, even with 1uF capacitive load. Step response is smooth, no overshoot. The implication would be stability.
But looking at the amplitude and phase, it seems that there's way too much phase to allow the loop to be closed and remain stable. The closed loop is stabilized with the addition of between .68pF and 1.5pF across the FB resistor (301K Ohm).
What am I missing with gain and phase margin here?
Old 10th February 2013, 03:57 AM   #2
djoffe is offline djoffe  United States
maybe it's just a minus sign, but at low frequencies, the phase is 0 degrees, not -180.
Can you post the schematic?
Old 10th February 2013, 04:32 AM   #3
If you look more closely, you'll see the phase is zero at low frequencies. It reaches 180 degrees at around 600KHz in the open loop plot.
The schematic is rather cumbersome. But I'll try and clean it up and post a partial.
One correction. The 1pF cap is from the drive to the MOSFETS, not directly across the FB resistor.
Old 10th February 2013, 04:40 AM   #4
The zero phase at low frequencies is what has me going...doesn't that say that it's positive feedback at low frequencies, which means it would latch up at DC?
That's why a look at the schematic might reveal the mystery, I hope.
Is it in LTSpice? If so, could you post your .asc file?
Old 10th February 2013, 04:57 AM   #5
It's a non-inverting amp. That's why at low frequencies the phase is zero. It's in phase with the input.
Here's a shot of the schematic. There are a few more MOSFET sections.
It's a JFet differential input which drives a complimentary differential pair. All three of those are fed with current sources. The complimentary pairs are also loaded with current mirrors which function as the drive signals for the MJE340 and 350.
The modeled performance is pretty dang good too. Here's a shot of a simulation using a signal with a 10:1 crest factor (music facsimile) using 10 tones in two closely spaced groups to highlight IMD performance. 60V peaks into 8 Ohm. It stays virtually identical when loaded with 4 Ohm.
For the Bode Plots, I removed the input capacitor so that the plots showed only the amp itself. The 1uF cap at the output has a series resistance of 1K, basically out of the circuit.
Old 10th February 2013, 05:14 AM   #6
Maybe this explains it? The phase shift where the 1pF cap is taking its feedback is lower than the overall phase shift and that's what gives the phase margin for stability?
It's been a while since my days of loop stability analysis. I can feel the rust breaking off the cogs upstairs.
Old 10th February 2013, 05:27 AM   #7
Pete,
I think that your loop gain measurement methodology might be suspect. It's typically done by putting a source in that isn't the input.
In your circuit, you'd drop an AC source between the R3-R5 junction and the gate of J2. The loop gain is then the ratio of the R3-R5 voltage to the voltage at J2's gate. Maybe you made the measurement like that, but it's hard for me to tell without being able to see the source.
This is also one of those front ends that makes me worry owing to two dueling high gain stages. The Q-point is kind of fuzzy...easy way to see that would be to add 1 mV of offset to one transistor in the input stages, and see how much the current in the VAS changes.
Catch you tomorrow!
Old 10th February 2013, 05:28 AM   #8
keantoken is offline keantoken  United States
keantoken's Avatar
Your simulation parameters are too minimalistic. Since LTSpice is optimized for logic and switching, it comes default with data compression and low accuracy settings. Add these parameters to your schematic and see what happens:
.options plotwinsize=0
.options method=gear
.options numdgt=7
Also try removing C2 and see if it's still stable. Or give C2 some ESL.
To get a lower noise floor, select the Hann or Blackman window in the FFT dialogue.
I like R19 and R14. If the Hfe of the VAS can be counted on, bias may be stable. It would be interesting to see the influence of temperature and various things in the real prototype. Cascoding would make Hfe more stable.
If the output is shorted, which will fry first, Q7 or Q2?
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 10th February 2013, 05:46 AM   #9
jcx is offline jcx  United States
adding a fet front end doesn't fix the Slone complementary diff pair + current mirror indeterminate VAS bias problem - you really need to understand the issue and fix it up before wasting time simming something that won't work with real components
Old 10th February 2013, 06:40 AM   #10
.options numdgt=7
Thanks for the suggestions.
I had already removed compression and set the time step to 1us. But I did add your directives and re-ran the sims on both the closed loop gain and the 10 tone signal. Hann window on the FFT.
Maybe you missed my comment earlier. C2 has a 1000 Ohm series resistance for the simulations. It's hanging there so that it's easy to change and check stability with capacitive loads.
Q2 and Q7 are separated by a couple hundred ohms which limits the current to about 120ma peaks. Output current will be set to about 15A peak at which point the power supply fuse should have easily blown. We'll see if it's adequate or other protection needs to be added.
Input for the simulation is sent to the "Source" input of the dependent source on R2. The 30dB gain is set by the ratio of 301K / 10K. The 68pF cap was removed for the simulations to see the entire loop character without the LPF at the input.
R19 and R14: they will be set during testing to fix the bias current in VAS to somewhere between 20 and 30mA. I also have R9 and R10 so that I can further stabilize the drive transistors if need be. R7 and R8 also help bring a determinate state to the current mirror output levels. They can be modified to help set bias as well.
The JFet front end is not there to "fix" anything about the Slone pair or indeterminate VAS. The JFET front end adds a bit of gain and gives me the high input impedance I was after. It's also a low noise, matched pair, which doesn't hurt either (Linear Integrated Systems LS844). Besides, I can always remove the mirrors and replace them with fixed resistors and set the VAS bias that way, but it will give away a few dB of gain.
But back to the original point about phase shift and loop stability . . .
Loop stability clarification . . .Hide this!Advertise here!
Closed loop stability help needed. TheGimp Tubes / Valves 58 24th December 2011 01:15 AM
opamp + buffer feedback loop clarification Archwn Solid State 18 10th April 2011 04:16 AM
NFB Clarification cbj591 Tubes / Valves 9 17th July 2010 02:17 PM
An attempt for clarification. Lumba Ogir Solid State 1 4th March 2009 07:46 PM
hum,ground loop,earth loop problem with your answers please frank2395 Pass Labs 2 17th May 2005 06:46 PM
