Nyquist stability
Nyquist stability
Old 8th February 2013, 10:15 PM   #1
danny92 is offline danny92  Portugal
Default Nyquist stability
Hello everyone,
I'm designing a solid state power amplifier, and I'm adjusting the dominant pole capacitor at the VA stage. The problem is the phase shift that is near 180 degrees (175 degrees actually) at the output with 0dB voltage gain, could the amplifier meet the Barkhausen criterion and start self sustaining oscillations?
What I've to do to prevent this from happen?
Bode diagram attached,
Best regards,
Daniel Almeida
Old 8th February 2013, 10:19 PM   #2
Attached is the Nyquist plot.
Old 9th February 2013, 12:14 AM   #3
Default Reducing Qvbe bias resistor value
Hello everyone,
I've reduced the Qvbe bias resistor values and the phase shift is now between 150 and 160 at 0 dB (I think that those are acceptable values).
If I use a small capacitor between 30 and 50 pF, I've some kind of voltage gain "peak", I've simulated the progress of the output voltage at that frequency, and I've got a distorted signal but no positive feedback or oscillation.
When I use capacitors between 300-500 pF I've got terrible THD+N characteristics at 20kHz, and the 1kHz THD+N characteristics gets worse but the peaks disappear, why is this happening?
What's the best option?
Thank you very much for your concern,
Best regards,
Daniel Almeida
Old 9th February 2013, 12:26 AM   #4
Hello everyone,
I've made this graphic using LM4702C (with the circuit similar to the one found in app note snaa045) to drive IRFP240/IRFP9240 and the result is similar, a gain "peak" is present, maybe the problem are the output devices?
Or TINA TI simulator?
Thank you very much for your attention,
Best regards,
Daniel Almeida
Old 9th February 2013, 12:28 AM   #5
Mark Johnson is offline Mark Johnson  United States
Mark Johnson's Avatar
Nyquist stability
Maybe a .TRAN analysis would give you additional insight into the circuit behavior?
If version_1 of the amplifier has gain-peaking in the AC analysis, but version_2 of the amplifier has no peaking, perhaps it would be revealing to simulate driving each of these amplifiers with a 1 volt peak-to-peak ideal square wave input (-0.5V to +0.5V), then look at the .TRANsient output.
Old 9th February 2013, 12:46 AM   #6
Thank you very much for your fast reply
I've simulated both with sines at the frequency of the highest peaks and the wave becames distorted but with the same amplitude.
Maybe the problem could be the output pairs used?
PS: LM4702C TI amplifier also has gain "peaking", and I think that's strage.
In audio range the amplifier is linear and the sine waves are almost pure.
Best Regards,
Daniel Almeida
Old 9th February 2013, 01:00 AM   #7
djoffe is offline djoffe  United States
did I miss it? Is there a schematic posted?
Old 9th February 2013, 01:43 AM   #8
Hello evreryone,
Attached is the schematic of the circuit I'm testing.
This is a mirror image amplifier, with push-pull VA stage (current limited) and cascode loading, the constant current sources of the differential amplifiers are feedback current sources, the amplifier as two single pole compensation capacitors, the output stage consists of a vbe multiplier for output devices biasing, and also as short circuit protection and against inductive loads (with clamping zener diodes), the MOSFETs have gate stopper resistors to prevent high frequency oscillations, I've a resistor from sink to ground to reduce 2nd harmonic. The output stage consist of two vertical MOSFETs IRFP240 N-channel and IRFP9240 P-channel, the amplifier has a gain of aprox. 30 V/V for AC and 1 V/V for DC, the input is AC coupled, this amplifier also includes a Boucherot Cell (Zobel Network) to filter high frequency oscillations.
Thank you very much for your help,
Best regards,
Daniel Almeida
Old 9th February 2013, 02:06 AM   #9
Dave Zan is offline Dave Zan  Australia
Hi Daniel
This architecture looks attractive but has problems.
They have been discussed extensively - search for "Heeeelllppp"
The schematic in little pieces does not help, or at least it doesn't help me.
It is a creative way to achieve modularity but perhaps it would be easier for others if you presented your circuit more conventionally.
Best wishes
David
Old 9th February 2013, 02:07 AM   #10
The current in your VAS stages will be pretty well indeterminate, or limited by your current limit circuits in the cascode path, neither of which you really want to happen.
You have two dueling high gain points, and even if you've made the simulator happy, real life won't be very kind.
Perhaps as an experiment, you could replace one of the VAS's by a constant current source...I know this won't preserve the mirror image characteristics, but as it is, I don't think it will behave well.
Once that's sorted out, the next issue is that the typical simulator mosfet models are awfully crude, and typically not very trustworthy. Perhaps yours are better than most.
Nyquist stabilityHide this!Advertise here!
testing for stability maxpou Solid State 70 24th March 2012 08:09 PM
stability of my preamp maxpou Solid State 4 25th October 2009 03:12 PM
Nyquist-Shannon and Lesbeque Keruskerfuerst Everything Else 1 6th January 2008 09:24 PM
I want to discuss the Nyquist theorem, anyone interrested? mr_push_pull Digital Source 49 3rd February 2005 07:56 AM
stability djdamix Solid State 3 7th January 2005 07:30 AM
