Hello.
I am having a problem which I am unable to resolve myself because of my lack of electronic knowledge. I've build an objective2 amp and the left channel is not working. I can only hear loud "boom" noise when switching the amp on or off. Right channel is working OK. I am measuring about 13v of DC on this channel's output (measured from P2). I've already build 2 O2s in the past and I've never experienced similar problem. Does anyone know what the problem might be? I don't know much about electronic stuff so I have no idea what to do. Sorry for my english
#2 | |
The Objective2 (O2) Headphone Amp DIY Project Chk the input socket, it might be faulty or dry soldered. Use one end of i/p pin & chk for continuity of the i/p socket(blue)
Thanks, availlyrics |
#3 |
Try reheating the solder connections on R13, even if they look perfectly good.
#4 | |
WARNING: don't connect your HD800 yet. 13 VDC is too much. List the issue on The Objective2 (O2) Headphone Amp DIY Project
#5 | ||
I did follow the NwAvGuy's trobule shooting guide once more and here are the results. At Initial DIY Testing section I am failing Check The Raw DC Voltages part. Here are the results: ![]() After that I jumped to Troubleshooting Problems section and I think there is something wrong at Negative Unregulated Supply part. This is what I got: ![]() Anymore ideas? Last edited by ProTofik; 9th February 2013 at 09:59 PM. |
#6 | |
You should be getting close to -12Vdc on pin 4 and +12Vdc on pin 8 with the AC adaptor plugged in and the O2 turned on. If one of those voltages is missing, do the same tests between ground and pins 4 and 8 of U2, the NJM2068. If you get +/-12Vdc there but are missing one voltage on the output chips then one of your mosfets is not turning on. Last edited by agdr; 10th February 2013 at 12:58 AM. |
#7 |
Thanks for reply. I will check it tomorrow.
I will also reupload missing attachments tomorrow as I don't have an access to my PC now. |
#8 | |
I've attached the files that were currupted in previous post.
U3 - Pin8 = 11.71V U4 - Pin4 = -16.63V U4 - Pin8 = 11.71V |
#9 |
With the wall adapter plugged in, but the O2 turned off, measure the voltage across C7. It should be close to -12VDC. If it isn't, check that U6 is installed correctly, and that everything from J1 to D5 is as per the schematic.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine |
#10 | |
Use a magnifying glass to check - I've found it is nearly impossible to see a short there without using one. Edit: looks like sofaspud and I were composing at the same time - and we agree on where your problem is. See what you find there.
| Objective2 parts / kit | bearmann | Swap Meet | 2 | 25th June 2012 12:25 PM |
| Put amp in chassis, then, right channel doesn't work! | ambience exists | Tubes / Valves | 11 | 4th August 2008 10:30 PM |
| About NAD S200 R channel is no work!help... | Wizard | Solid State | 0 | 24th January 2008 02:02 PM |
| Counterpoint SA100 one channel doesn´t work | Orgonom | Tubes / Valves | 3 | 14th January 2007 04:21 PM |
| Right Channel on my amp doesn't work?? | nicku1302 | Solid State | 2 | 29th November 2005 03:58 PM |
