Old 8th February 2013, 11:08 AM   #11
DF96 is offline DF96  England
Originally Posted by KatieandDad
Class D used to only use the peaks of the output waveform, useful for SSB Radio Amplification, useless for audio.
No. SSB needs a linear amp, so usually Class B. I have never heard Class D used for anything other than the switch-mode amplifier used for audio and modulators.
Class D could be used for SSB as part of an EER system, but that uses a different principle so the Class D amp still operates in the normal way we understand today.
Class D should not be regarded as the next one after Class C. Instead, it should be seen as the first of the switch-mode amps: classes D, E and F. E and F are only used for narrow-band applications such as RF or fixed-frequency energy conversion.
Old 8th February 2013, 12:47 PM   #12
jackinnj's Avatar
Jim kyle wrote the "VHF Antenna Handbook" -- i still have a copy around here as i worked 6m and higher when i had my technician class
Old 8th February 2013, 12:57 PM   #13
The oldest circuit of a class-d amp that I have seen so far was from WW2. It was using tubes and it was inteneded to be used as 400 hz inverter (i.e. driven by a 400 Hz oscillator rather than an audio source). Can't remember the carrier frequency though.
Charles
Old 8th February 2013, 01:07 PM   #14
KatieandDad's Avatar
I'm not a radio man so I stand corrected.
Old 8th February 2013, 02:15 PM   #15
Originally Posted by unclejed613 View Post
......the article was by K5JKX. he mentions articles in Wireless World by D. R. Birt and K. C. Johnson, and a jun 63 Audio magazine article by George F. Cooper.
edit: maybe somebody else will have better luck, i have come up with zippo searching for the above authors or articles..
Maybe D.R. Birt was this one? AES E-Library A Motion Transducer for Low-Frequency Loudspeakers
regards
Old 8th February 2013, 04:01 PM   #16
flg is offline flg  United States
flg's Avatar
I'm thinkin ClassA is biased to work with the full waveform.
ClassB Uses only 1/2 the waveform but as we all know a complimentary style audio amp produces an output of the full waveform. It is effectively biased at zero.
ClassC however is only using some portion of the peak of the signal. Usefull in transmitters but useless for audio.
But, what do I know, I'm a dog
“Be who you are and say what you feel because those who mind don't matter and those who matter don't mind.” Dr. Seuss
FS/FT: Sweep and Ham Radio Tubes GordonW Swap Meet 2 10th November 2012 12:18 PM
Ham radio op makes his own triodes jackinnj Tubes / Valves 0 9th January 2008 02:18 PM
silicon chip magazine 15w class a amp jamesfeline Solid State 24 24th May 2007 12:01 PM
Audio DIY, kits and electronics for the Ham Radio Shack-India peterpan73 Introductions 1 14th February 2004 04:48 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
