diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Solid State (http://www.diyaudio.com/forums/solid-state/)
-   -   Marantz M9 clone in bridge (http://www.diyaudio.com/forums/solid-state/229390-marantz-m9-clone-bridge.html)
Stee 5th February 2013 09:48 AM
1 Attachment(s)
This project is intended for connection to bridge with input transformer
have diamond input solution and very low feedback (set to 40dB) :)
Stee 7th February 2013 05:56 PM
new version
1 Attachment(s)
the diamond buffer stage drives a voltage then a current stage
with exactly the same mode
the gain is different only for feedback shutter :confused:
Stee 19th June 2015 08:57 PM
from ebay
5 Attachment(s)
sharbatgula 19th July 2015 09:29 AM
I've seen this amp on aliexpress and e-bay too. So, have you tried it? Someone on diyaudio has written that the measured slew rate is very low 4V/uS for a current feedback amplifier.
Stee 19th July 2015 01:39 PM
not yet
1 Attachment(s)
but I have a new project :cool:
IPANEMA AMP
Stee 20th July 2015 06:09 AM
modify the original VAS current
1 Attachment(s)
a solution can be this
doubling the current that drives the output stage follower
just add a resistor in parallel for each branch:bulb:
Resources saved on this page: MySQL 18.75%
