Old 6th February 2013, 01:39 PM   #41
can I know why hiraga super class A 30w doesnt have this RL.
http://diyaudioprojects.com/Solid/Je...-Schematic.png
Can I know how its not oscillating.
Another question is that there are no Emitter resistors which is still good for higher fidelity as there are no passive components in the path.
can we use such resistor less pushpull config? I do understand the importance of it so how come the hirga amp doesnt have it...
I know a friend of mine built hiraga and also F5 says hiraga is way too ahead of F5 even though Nelsons designs are very famous. What could be the reasons...
I have even seen Nelsons schematics no amp has got a RL they might have RC shunted but not RL...
Im a bit confused..
ill get the measurements soon..
Old 6th February 2013, 07:43 PM   #42
llwhtt is offline llwhtt  United States
Since you mentioned that some Nelson Pass's amp don't use an RL network on the output why don't cruise on over to the Pass forum and ask him. I'm sure he will fill you in on the whys and why nots.
Craig
Old 7th February 2013, 01:40 PM   #43
JMFahey is online now JMFahey  Argentina
JMFahey's Avatar
It's impossible that the few uHy typical "stability inductor", normally consisting of less than 20 turns of enamelled wire around a 1W resistor, cut output above mere 14 KHz.
I think you used a "bought" inductor and misread or mis ordered its value.
Go for the simple DIY solution and remeasure.
Or your problem lies somewhere else.
Old 7th February 2013, 01:54 PM   #44
like the way its said in previous thread it looks like the NFB where the upper freq is cuttoff at relatively lower freq...
But i tried cutting the Inductor to 4 turns and now its much better but im just doubtful that will that work fine in terms of stability
Old 7th February 2013, 02:52 PM   #45
absolutely there is something wrong...
I have simulated the circuit with TinaTI with all the same values used in the schematic and im getting a very bad response
please have a look..
I think somebody said in the previous posts that the prob with NFB it seems right...
what I need to do is to rework on the NFB can anybody recommend me the values?
Old 7th February 2013, 03:08 PM   #46
R1C1 need to be before the output inductor
Old 7th February 2013, 04:09 PM   #47
changed the position of R1 C1 still getting the same freq response...
Old 7th February 2013, 04:19 PM   #48
JMFahey's Avatar
There's nothing in your schematic on post#19 which can justify such response.
And with the huge peak you show !!! .
Old 7th February 2013, 04:44 PM   #49
after some time in tweaking the values I finally got this..
This is the actual sch
now after changing the values Im getting this but if there is something pretty small in the previous ckt pls tell me that I can fix..
Can we go with these values?
Old 7th February 2013, 05:00 PM   #50
aha it seems i finally got what is the wrong with this ckt its the RC network at the output..
the C1 Cap stated in the design is 100nf it has to be 100pf and everything works fine on the simulation..
Ill do this practically and see the results...
Mic preamp - strange high frequency roll off problem Andyroid Tubes / Valves 31 6th January 2013 09:08 PM
HELP: Eimac 75TL amp high frequency roll off HP8903B Tubes / Valves 71 30th April 2012 03:53 AM
Buffers high freq loss trv Construction Tips 21 22nd May 2010 10:53 AM
TDA1562Q low freq roll-off DrLex Chip Amps 7 8th December 2009 02:37 PM
H-Frame High Frequency roll-off? DIY_newbie Multi-Way 7 13th September 2005 04:06 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
