what could be the reasons for High freq roll off after 14khz
Old 18th February 2013, 05:55 PM   #71
rhythmsandy is offline rhythmsandy
yeah checked with multimeter short test yes base and collector are shorted... so how far the amp be biased in this case? I believe thermal runaway was started..
Old 18th February 2013, 06:09 PM   #72
llwhtt is offline llwhtt  United States
Yep, that's the only way to get enought current through the resistor to burn it up, especially a base resistor. You probably experienced thermal runaway, too small of heatsink, too much idle current, and it just took off when it got hot enough.
Craig
Old 18th February 2013, 06:16 PM   #73
In an AB amp the bias is "usually" set just enough to eliminate crossover spike as seen on an o'scope. But you usually never see that in the service manuals, usually a number is given, so many mv across a resistor or ma across an open fuse holder, whatever. These numbers will get you past the crossover spike but if you were to use the proper test equipment and set the idle current to just to eliminate the spike you will find the number is usually lower than specified.
Craig
Old 18th February 2013, 07:42 PM   #74
i did bias it at 500ma and found the heatsink hot the heatsink is an igbt one which measures 150mm length x 126mm width and 126mm height and weighs about 5kg...
but still it gets hot... I thought about 50w class A I can just imagine just with 500ma bias 4w how much hot it becomes...
so I measured across the emitter resistor .22 ohms so is this peak current or continuous?
Old 18th February 2013, 08:00 PM   #75
but altogether i enjoying the 4w class A at that time now just biased the other channel to 250ma and still able to get 2 watts of classA at lower volume the treble is very transparent and mids are very involving... i dont know how much precisely the wattage at the output but the heatsink is almost hot...
i am working on LME49830 with about 4 pairs of IRFP240 and irfp9240 which might give better current sharing altogether but I have underestimated the heat problems and thermal runaway with higher bias..
Old 18th February 2013, 08:05 PM   #76
I don't think I would use either of those terms, peak or continuous, to describe setting the idle current. The idle current is usually described as quiescent.
How are you determining Class A output?
Craig
Old 18th February 2013, 08:09 PM   #77
im using the pot which alters the VBE and hence the current in the source resistor.
I=Vsourceresistor/Rsourceresistor
what could be the reasons for High freq roll off after 14khzHide this!Advertise here!
Mic preamp - strange high frequency roll off problem Andyroid Tubes / Valves 31 6th January 2013 10:08 PM
HELP: Eimac 75TL amp high frequency roll off HP8903B Tubes / Valves 71 30th April 2012 04:53 AM
Buffers high freq loss trv Construction Tips 21 22nd May 2010 11:53 AM
TDA1562Q low freq roll-off DrLex Chip Amps 7 8th December 2009 03:37 PM
H-Frame High Frequency roll-off? DIY_newbie Multi-Way 7 13th September 2005 05:06 AM
Copyright ©1999-2017 diyAudio
