tash ma hall amp
this project is characterized by a high circulating current
especially in the differential input stage
in fact is a current mirror CFP
the next stage is characterized by a bootstrap titpico schema Jeff Rowland
Then the typical triplet EF emitter follower
if you like to use the simulator calculates the optimized values ​​of 35V dual
Thanks:D
Crossover
I would like to do the speakers for amplifier 60W RMS / 8 ohm. I watched the speakers Woofer Beyma 8BR40/N - 50W RMS, 35 - 6000 Hz, 90 dB, 8 ohm and Tweeter Beyma T2030 - 15W RMS, 1,5 - 20KHz, 95 dB, 8 ohm with crossover Beyma V2 hifi, 300 W, freq 3 KHz, 8ohm.
I turn to you, because I'm not so sure that this is a good relationship and frequency of cutting 3 KHz correct
Would it be better if I would use stronger tweeter and would cut the freq to 4 or 5 KHz
Does anybody can help me with advice and calculation for crossover
Best regards
