tash ma hall amp
tash ma hall amp
Old 5th February 2013, 02:07 PM   #11
TANDBERGEREN is offline TANDBERGEREN  Norway
The C-B of the two transistors are coupled in blocked mode.
There will not flow any current from the collector up to the B-E-joint.
Again, what ais the purpose of the two PNP-transistors on the diff input stages collectors?
Sooner or later you end up with TANDBERG
Old 5th February 2013, 02:25 PM   #12
Stee is offline Stee  Italy
Stee's Avatar
normally in the input stage using transistors with low Ic on the natural bias voltage 0.6 V
this method allows to obtain a driving current of the stadium in tension much wider because the BJT PNP has deliberately characteristics of current@0.6V higher
Please download my best audio idea https://www.facebook.com/DiyAudioHiEnd
Old 5th February 2013, 03:29 PM   #13
jancopanco is offline jancopanco
Exclamation Crossover
I would like to do the speakers for amplifier 60W RMS / 8 ohm. I watched the speakers Woofer Beyma 8BR40/N - 50W RMS, 35 - 6000 Hz, 90 dB, 8 ohm and Tweeter Beyma T2030 - 15W RMS, 1,5 - 20KHz, 95 dB, 8 ohm with crossover Beyma V2 hifi, 300 W, freq 3 KHz, 8ohm.
I turn to you, because I'm not so sure that this is a good relationship and frequency of cutting 3 KHz correct
Would it be better if I would use stronger tweeter and would cut the freq to 4 or 5 KHz
Does anybody can help me with advice and calculation for crossover
Best regards
Old 5th February 2013, 04:02 PM   #14
llwhtt is online now llwhtt  United States
Why are you asking about speaker crossovers in an amplifier forum?
Craig
Old 5th February 2013, 07:29 PM   #15
Craig
Probably because I registered for the first time today and I'm still a beginner. Please help me.
Old 5th February 2013, 07:42 PM   #16
Go to the forums list, Look up the group "Speakers"
There You will find "Multi-Way" as the forum where it would suit fine to post your question.
Start by clinking this link: http://www.diyaudio.com/forums/multi-way/
Old 6th February 2013, 03:33 AM   #17
DUG is offline DUG  Canada
Now I see what it was supposed to be.
Base connection is in the wrong place in post #1 schematic.
OK, thanks for clarifying your intent.
Doug We are all learning...we can all help
"You can't stop the signal, Mal. Everything goes somewhere..."
Old 6th February 2013, 04:30 AM   #18
Workhorse is offline Workhorse
Workhorse's Avatar
Stee what is TASH MA HALL ??
Or is it poor man's version of TAJ MAHAL
Old 6th February 2013, 06:23 AM   #19
Ian Finch is offline Ian Finch  Australia
Well, we know Stee has a good sense of humour, when you also look at the previous thread titles...
If only I had listened....
tash ma hall ampHide this!Advertise here!
For sale: 2 x Fivre 2A3 Single Plate, 60 mA + 44 mA emission on Funke W20 2A3 Maniac Swap Meet 3 1st October 2011 12:18 PM
Crown MA-12000i / MA-5000i / MA-9000i jack2040 Solid State 4 8th March 2011 01:21 PM
MA Audio AMP mike49504 Car Audio 4 23rd September 2010 08:45 PM
Music Hall MMF-5 turntable & Custom Pre-amp(Hagtech Bugle+PSU+volume+switch,etc) Destroyer OS Swap Meet 2 6th October 2008 04:49 PM
Marantz MA 500 or MA 700 schematic krishu Solid State 0 15th March 2004 01:59 PM
