Passive pre amp vs powered pre amp - Page 3 - diyAudio
Old 20th November 2003, 08:37 PM   #21
Fatmarley, your attenuator is a little on the high side and your amp input z is a bit low but there's no harm in giving it a go, it won't damage the amp. I'm sure the results will be ok if not optimum, just keep the lead between attenuator and amp short.
I had no idea Naim amps were so sensitive to speaker cable length, must be a design 'feature'
Old 21st November 2003, 03:01 PM   #22
It seems Naim amps rely on having the 'right' cable attached to guarantee stability. There's some discussion of it here:
I don't believe cables make a difference, any input?
Cheers
IH
Passive Crossover for Passive Subwoofer? Toast_Master Subwoofers 23 30th April 2006 01:14 AM
help fix my powered sub.. alex paik Subwoofers 9 31st March 2006 01:40 AM
Passive or Powered? JRKO Solid State 13 13th August 2004 08:21 AM
dB loss by using passive crossovers? Active vs Passive and 1st vs 4th order Hybrid fourdoor Multi-Way 3 11th July 2004 10:16 PM
Help in transforming a powered subwoofer in a passive one!!! Rimbaldo Subwoofers 5 19th June 2004 06:26 PM
Copyright 1999-2017 diyAudio
