the G amp ....
the G amp ....
Old 2nd February 2013, 08:48 AM   #11
Ian Finch is offline Ian Finch  Australia
Hi Sakis,
Look at the second 4,700uf output cap. The bottom (-) connection has no dot. (signifying no connection to the output). When there is no conflict, like a T junction, no need for a dot. For a X junction, it can be either a junction or a crossing.
So, to be obvious, it looks like only one 4,700uf output cap and another 4,700uf in series with 560R to ground. Of course, I hope I know better but maybe.... I don't?
Ian
Old 2nd February 2013, 11:26 AM   #12
alex mm is offline alex mm  Romania
alex mm's Avatar
...... I think schematic it's like in attachment
Old 3rd February 2013, 08:37 AM   #13
east electronics is offline east electronics  Greece
east electronics's Avatar
ok ...got it
intention remains to construct and listen
will keep you posted
In between any suggestions are welcome
Kind regards
Sakis
SERVICE ΕΝΙΣΧΥΤΩΝ ΚΑΙ ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 18th May 2013, 01:44 PM   #14
ivanlukic is offline ivanlukic  Serbia
Originally Posted by sakis View Post
My article ""the G amp"" while G means Geriatric was based on that concept and was found not to have that much interest anyway http://www.diyaudio.com/forums/solid...120-g-amp.html
I missed this thread for unknown reason. Do you have pcb design tested and debuged?
Old 3rd August 2013, 09:40 AM   #15
PCB is not made yet ...It will be done with in August which is a vocation month for non audio people ...
In between one placed a question regarding power supply and if hypothetically there was another regulated power supply of a few volts more say 5-10 to supply with different voltage first stage and output
Comments on that please ... my estimation is that will create a better clipping condition if and ever needed but the real question is if its expected to improve overall performance and increase dynamics .
Kind regards
Sakis
Old 4th August 2013, 08:14 PM   #16
indianajo is offline indianajo  United States
indianajo's Avatar
Still listening. 4700 uf output caps are SO cool as speaker and output transistor protection compared to the 30 part (and growing) relay protection circuit I'm building for my PV-1.3k. I've bought 100 VCT 1.5 amp transformers (to use one side), MJ15015 , TIP41-42C, and MPS8099 instead of your European transistor selection. I did buy a couple of actual LM317HVT's for the regulator, assuming it has something to do with decreasing bias current when hot.
As far as clipping, I've never heard any, but I'm running the NTE181 output transistors on my ST120 at 80 V rail, so with a 1.5 Vpp (8 ohm) start to Tchaikovsky's 1812 Overture the cannon shots don't cause clipping. We'll see what 63 v rail does in your original design.
Dynakit ST70, ST120, PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey CS800S,1.3K, SP2-XT's, T-300 HF Proj's, Steinway console, Herald RA88a mixer, Wurlitzer 4500, 4300
Old 15th September 2013, 11:49 AM   #17
maouna is offline maouna  Greece
any progress sakis? i am interested in building an amp of such a topology ...
Old 15th September 2013, 07:47 PM   #18
jerluwoo is offline jerluwoo  United States
jerluwoo's Avatar
Almost identical to the Marantz 2215B power amp section that many people liked the sound of. With the quality PS and modern transistors this should make for a nice little amp.
Old 22nd September 2013, 06:07 PM   #19
just ignore this post.wrong thread.
the G amp ....Hide this!Advertise here!
FS- Twisted Pear Buffalo 32S Board & System New & Unused secretriches Swap Meet 1 10th August 2009 03:17 PM
Modify & build out (2) Western Electric 300B / 2A3 Hammond monoblock amps & UTC LS-5 quality sound Tubes / Valves 0 9th May 2009 04:59 PM
Krell KSA 80 bias & dc offset check & adjust procedure Clouseaupte Solid State 3 9th August 2007 10:39 AM
DIY-AMP <ZAS> Low THD & IM high bandwith murphy Solid State 18 30th December 2005 11:28 AM
Copyright ©1999-2017 diyAudio
