Power amp just buzzing! Need help with diagnosis.
Old 2nd February 2013, 06:31 AM   #11
lowpoke is offline lowpoke  Australia
Originally Posted by megajocke View Post
Isn't it the one right there inside the red rectangle, next to the aluminium clad resistor?
The failure might very well be in the soft start circuit, causing the relay to buzz.
This would be good news right?
Show us what ya got at Homebuilt Hi-fi
Old 2nd February 2013, 07:09 PM   #12
Ian Finch is offline Ian Finch  Australia
Isn't it the one right there inside the red rectangle, next to the aluminium clad resistor?.....
The black square block? That could well be the small delay switch relay but 30A/250 VAC rated? I am not so sure there. Still, a bad relay any size can certainly buzz.
Yes lowpoke, that would be simple for the repairer, if he can get suitable replacement parts.
Ian
Old 3rd February 2013, 04:56 AM   #13
megajocke is offline megajocke  Sweden
megajocke's Avatar
Ah, yes this seems to be the triac version, with a lower rated relay. Looking at the wiring diagram you have the three wires to the triac exiting the board right beside the resistor.
Old 22nd February 2013, 11:04 AM   #14
UPDATE:
So I finally got my amp back from the workshop. Apparently the small black caps to the upper right of the red rectangle (in the image in my first post) were leaking. There were also apparently some dry joints that were also resoldered on that board.
They gave me the original caps back, but they looked perfectly good. No physical signs at all of any leakage.
Anyway, amp is working beautifully again now and the repair bill was totally reasonable!
Old 22nd February 2013, 02:24 PM   #15
lanchile is offline lanchile  United States
lanchile's Avatar
Originally Posted by lowpoke View Post
UPDATE:
Leaky caps, That is nothing new since this amp is more than 20 years old. I would change "all" those electrolytic caps using high grade and temp like 105c caps. To check those caps you will need an E.S.R meter, most of caps look good to the eye but as soon as you put them under the E.S.R meter...all changes!
Power amp just buzzing! Need help with diagnosis.Hide this!Advertise here!
Buzzing power amp - DC blocker has no effect Radioactivebloke Solid State 7 19th September 2012 12:29 AM
what makes power transformers buzzing samoloko Power Supplies 4 3rd December 2008 07:22 PM
Faulty amp - diagnosis? Omega_Void Solid State 7 11th July 2008 10:52 AM
buzzing power supply keyser Solid State 1 9th March 2005 08:51 AM
buzzing and pop sound when fender power amp is turned on zaboomafoo Everything Else 0 27th August 2004 05:12 PM
Copyright ©1999-2017 diyAudio
