#41 |
I always use Cricklewood Electronics in London. Never had a problem with them.
Do a search on google and you'll find them. |
#42 |
I'd recommend sticking to a worldwide supplier such as Farnell, Digikey or Mouser. They should all ship to Portugal.
#43 |
Ok...today i buy a few things...there's some that i can't find yet...but this ones give me some work to do for now...
I already buy the Fuses to...so late today i will start and test the power suply... Regarding the TIP's i found the 2955 ones...any problem with different brand? thats wath i got... ![]() Regarding the 7815/7915 whats the best way to test? |
#44 |
isc is inchange semiconductor.. a chinese company well known for making fake Sanken transistors.
The best way to test 7815 is to feed at least at least 18V into it, and see if a stable 15V comes out. Put some small load on the output e.g a 47 ohm 1W resistor for a current load of ~32mA. Similar for 7915. See their datasheets for the relevant info. |
#45 | |
#46 |
Not from eBay - this is pretty much the number one source for getting fake parts.
The only place I can recommend you would get genuine high quality parts from is the big companies like Mouser, Digikey, RS and Farnell. They all get their stocks direct from the manufacturers. |
#47 | |
#48 |
Regarding ZTX753....
is the replacement for FST240 right? and ZTX653 for the FST239 i found 2xFST240 the last ones on the store... |
#49 |
By the way: MJE2955T and MJE3055T will also be up to the job. Originals is available "everywhere". Also I can manage to get hold on some TIP2955/TIP2955 from ST. Around $5,-/each.
Sooner or later you end up with TANDBERG Last edited by TANDBERGEREN; 11th February 2013 at 04:09 PM. |
#50 |
The FST239/240 have not been made in over 20 years - i will be very very surprised if you find originals.
Stick with ZTX653/753 |
| Arcam Alpha 3 | Carlosraj | Solid State | 2 | 3rd October 2011 07:23 AM |
| Arcam Alpha plus v. Alpha 5 plus v. Rotel RCD 855 | dynoPort | Digital Source | 1 | 30th March 2011 11:19 AM |
| Arcam Alpha 8R repair advice | tmr510 | Chip Amps | 1 | 12th September 2010 07:46 PM |
| Arcam Alpha 7 Repair | big jim | Solid State | 1 | 26th June 2006 02:10 PM |
| Arcam Alpha 8 | ManUtd | Digital Source | 4 | 5th April 2004 02:23 PM |
